Transmission Oil question? - JeepForum.com
post #1 of 4 Old 02-22-2012, 10:13 AM Thread Starter
jduress
I was thinking about draining and refilling my trans because I figure it has probably never been done and could use some fresh lubrication. Since the owners manual gives some AMC number that doesn't exist anymore I tried to look up what to use. I found sae 85w-90 GL5 was the most common, any advice before I drain it?, any suggestions? It is a borg T5 in an 85 cj7
jduress is offline
post #2 of 4 Old 02-22-2012, 10:52 AM
SkyJax
1978 CJ5
I have an 85' CJ7 with the T-5 as well. In my searches the fluid type seems to be a big debate but from what I determined this is what I "believe" is recommended. Bought it at NAPA.
SkyJax is offline
post #3 of 4 Old 02-22-2012, 11:14 AM
csabens
Not overly familiar with the T5 but if it has any brass or "yellow" parts, you need lower GL numbers so you don't disintegrate the parts. Ideally GL3, but most have been using that NAPA shown above that's GL4.
Big debates over this stuff, just run a quick search.
Daily Driven: 1985 CJ7 Renegade, 258ci 4.2L (TeamRushed and Nuttered), T176/Dana 300 (in need of an overhaul), Weber 38 DGES, Ion Alloy 174 15x8, MasterCraft Courser MT 33x12.5x15, Front Axle Dana 30 w/ Superwinch Hubs, Rear Axle AMC 20 w/ one piece Alloy USA.
csabens is offline
post #4 of 4 Old 02-22-2012, 01:09 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
x2 on the Sta-Lube 85w90 GL4 from Napa. That's what I used:
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
advice help , cj7 , suggestions , transmission fluid
T5 transmission question stingercub2 Jeep CJ Forum 10 09-14-2011 03:42 AM
Transmission Question Splinter Jeep CJ Forum 0 08-02-2010 10:15 PM
transmission question nichols077 Jeep CJ Forum 2 06-13-2007 10:17 AM
Transmission Question Smoothy42 Jeep CJ Forum 1 01-17-2007 09:16 PM
86 cj transmission question klib321 Jeep CJ Forum 5 12-08-2005 07:16 PM
