Transmission Identification - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Transmission Identification
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 01-19-2015, 08:11 PM   #1
Yellow1981CJ7
1981 CJ7
Guys,
I recently purchased a CJ7 that was custom built by a previous owner so I am having to work my way through identifying the components as repairs are needed. The current project is to install transmission and 4WD shifter boots to try and keep fumes from coming into the cab. The engine is an AMC 360. The transmission is a manual 3 speed. How can I tell what specific transmission I have?
Yellow1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 01-19-2015, 08:55 PM   #2
BagusJeep
BagusJeep's Avatar
1981 CJ7
You need to get under the vehicle, take photos and find any numbers cast into the side of the box.
A useful website for basic identification is Novak transmissions, great resource.
As it is an AMC360 the number of possible cheap boxes that could be fitted without specialist adapters is quite low. It is more likely to have a 3 speed that came with the AMC V8. A possible is a Borg Warner T15 3 speed (quite strong and capable) - on the passsenger side cast in would be the numbers T15 or 1307, or 13-07-065-901
BagusJeep lives in Bali, the Land of Temples.
With a Jeep every prayer counts.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline   Reply With Quote Quick reply to this message
Unread 01-19-2015, 09:01 PM   #3
CSP
www.novak-adapt.com
www.jeeptech.com
Both have transmission identification pages. Picture here work too. Probably a T150, but it could be a T15 also.
CSP is offline   Reply With Quote Quick reply to this message
