Transmission help - JeepForum.com
post #1 of 2 Old 06-23-2013, 08:20 PM Thread Starter
oldskool73
1973 CJ5
Transmission help
Recently bought a beautiful 73 cj-5. about 4 weeks after purchase shifting became rough. now it's just about impossible. i have adjusted the clutch and it did not help. the transmission is leaking but cannot figure out where from. also, being that i have not owned something of this age, i can't figure out where to add transmission fluid. any ideas?
oldskool73 is offline
post #2 of 2 Old 06-24-2013, 07:24 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
The information you gave is a bit vague. Is it grinding in reverse and hard to shift in other gears? If so, you probably have an issue with either the clutch or it's linkage. I would insure the freepedal is correct (app 1"). Then visually inspect each piece of the linkage. Pay special attention to egging of the linkage rod holes, worn linkage rod ends, worn or missing pivots, bad body mounts (body lifting when clutch is depressed), and loose or missing pivot mounting bolts.
the filler hole is a square headed plug about half way up the side of the transmission.
jeepdaddy2000 is offline
