Transmission frozen????? - JeepForum.com
post #1 of 6 Old 12-08-2010, 03:32 PM Thread Starter
eng49ine
I have a 1981 CJ7 with the GM Iron Duke with a 4 speed. My transmission seems to freeze up when it get's cold!!!!!!!! I just changed the fluids in it with 80/90 gear oil.. Any ideas???? You can NOT get it out of gear!!
Thanks
Greg
eng49ine is offline
post #2 of 6 Old 12-08-2010, 04:17 PM
hp_lovecraft
1981 CJ5
I had the same problem with my 1981 w/ SR4. For me, I did not realize what was causing it until I managed to actually BREAK the shifter.
When I removed the old shifter, I looked into the shifting area, and it had about 1" of water! When cold, it would freeze the shifting components into a block of ice.
Could be other things, but at least an easy thing to fix if this is the case.
hp_lovecraft is offline
post #3 of 6 Old 12-08-2010, 04:22 PM
sbcranger
does it only happen when it gets cold? does it get any better once you warm the jeep up?
sbcranger is offline
post #4 of 6 Old 12-08-2010, 05:06 PM
Bakunin
Bakunin's Avatar
I had troubles shifting my T5. I know it's completely different, but I replaced the gear oil with the recommended Transmission fluid and the problems cleared up.
Bakunin is offline
post #5 of 6 Old 12-08-2010, 06:10 PM Thread Starter
eng49ine
Yes it only happens when it gets cold. It's fine after it's warmed up.
eng49ine is offline
post #6 of 6 Old 12-08-2010, 07:28 PM
sbcranger
sounds like the combination of the thick gear oil and the cold weather. my t5 is a little "stiff" before it warms up as well in the cold weather. i wouldnt be concerned as long as thats the only thing that seems off. let it warm up before you take it out.
Frozen locks.... meatloaf Jeep CJ Forum 9 03-23-2010 08:23 AM
frozen shifter CooterBrown Jeep CJ Forum 12 01-17-2010 07:31 PM
Help... brakes frozen?? buzzard86 Jeep CJ Forum 6 09-03-2006 01:54 PM
Frozen brake K.C.Jeep Jeep CJ Forum 3 03-17-2005 04:17 PM
Frozen Lug Nuts MFairbourn Jeep CJ Forum 12 01-14-2003 02:01 PM
