Transmission - JeepForum.com
post #1 of 2 Old 01-13-2010, 03:40 PM Thread Starter
br00klyn722
Transmission
does anyone know if the bell housing/adapter and fly wheel from a 85' CJ7 T4 will fit on a 85"cj7 T5 and match up with l6 258 4.2 engine?
br00klyn722 is offline
post #2 of 2 Old 01-13-2010, 07:32 PM
yellow85cj
258 bell housing for T4 and T5 are the same.
Flywheel for 258 with a T4 or T5 are the same.
Same for the pressure plate and clutch.
An AMC 150 bell WILL NOT bolt up to a 258. The T4 or T5 from a 150 has different input shaft spline count. You can use the T4/T5 from a 150 on a 258 but you have to get a clutch with a spline count to match.
IIRC the flywheel can be used.
Currently in pieces - all of them
yellow85cj is offline
t-150 transmission newjeepowner Jeep CJ Forum 7 03-14-2009 04:35 PM
AMC TH-400 Transmission Rickstitans Jeep CJ Forum 1 01-25-2009 07:49 PM
AMC TH-400 Transmission Rickstitans Jeep CJ Forum 1 01-25-2009 01:17 PM
What transmission do I have? '79 CJ7 gmshades Jeep CJ Forum 1 07-09-2007 12:58 AM
Transmission for a 350 wannachrist Jeep CJ Forum 15 06-27-2004 08:09 AM
