Transmission - JeepForum.com
post #1 of 4 Old 05-01-2013, 10:29 AM Thread Starter
kylem707
Transmission
I have a 1970 cj5 with a 4 speed and I'm trying to figure something out. It has three shifter levers one is to shift 1-4 one is to change from 2wd-4wdhi and low but the one in the middle I have no clue what it does? Can anyone help me on this?
kylem707 is offline
post #2 of 4 Old 05-01-2013, 12:01 PM
19jeep85
If it's not a twin stick transfer case shifter, you may have a PTO control lever.
The heart of the wise inclines to the right, but the heart of the fool to the left .
19jeep85 is offline
post #3 of 4 Old 05-01-2013, 12:07 PM
jeepwhore
Could be an overdrive unit as well.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #4 of 4 Old 05-01-2013, 05:57 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
CJ's with the V6 came stock with a single t case shifter up front on the right side of the tunnel cover.
A twin stick
The OD stick will be back half way between the front and rear of the transmission cover on the right side. It is usually vertical or have a slight bend to the rear.
The PTO stick will be centered in between the seats at the rear of the t case. It is usually short and straight.
jeepdaddy2000 is offline
