transfercase mount - JeepForum.com
post #1 of 4 Old 01-05-2005, 05:08 PM Thread Starter
gumby
gumby's Avatar
transfercase mount
can someone show me a photo or explain how the two piece rubber mount on a cj-7 with the 5spd tranny mounts. its a two piece rubber mount with a metal shaft that moves through the center and bolts thru the skidplate on the bottom of the frame.
1984 CJ-7 offroad special loves to get dirty and play rough. unlike the girls I meet
258 rebuilt with torquer cam/ weber 32/36 carb, HEI ignition ,headers 4 in lift AMC 20 detroit rear locked and trussed / tru trax front 4:56 Gears ,solid axles on 35's
"Two roads diverged in a wood and I - I took the one less traveled by, and that has made all the difference."-
Robert Frost
gumby is offline
post #2 of 4 Old 01-06-2005, 05:14 AM Thread Starter
gumby
gumby's Avatar
btt
btt someones got to know the manual dosent show it
Robert Frost
gumby is offline
post #3 of 4 Old 01-06-2005, 06:08 AM
CJ51973
CJ51973's Avatar
The stud mounts to the skid plate. There should be a torque arm extending out from the t'case (probably from the t'case mount area) with a hole in it. The stud sticks through with one of the rubber pieces on top of the torque arm and one below kind of like a stud type shock set up. Washers should back up these rubber pieces (nut, washer, rubber piece, torque arm, rubber piece, washer, stud). These are not squeezed together tight on mine. There is a little play to allow some movement (twisting) of the driveline. My experience is with the '79 and older setup but I would think they would be similar.
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #4 of 4 Old 01-06-2005, 10:17 AM Thread Starter
gumby
gumby's Avatar
I got it thanks
Robert Frost
gumby is offline
Transfercase help? fishooker04 Jeep CJ Forum 3 04-12-2009 09:41 AM
Identifing my transfercase wakes235 Jeep CJ Forum 12 03-13-2008 06:54 PM
Which Transfercase... elks96 Jeep CJ Forum 5 08-17-2007 10:31 PM
Overfilling Transfercase Carlsbad Jeep Jeep CJ Forum 3 02-19-2006 04:20 AM
which transmission/transfercase for a 360? JOKER4INK Jeep CJ Forum 8 10-18-2005 12:54 AM
