Transfer caser trouble - JeepForum.com
post #1 of 9 Old 09-10-2011, 06:06 AM Thread Starter
frankenstienCJ
1978 CJ7
I have a 1978 CJ7 304. With a t-150/amc 20 transmission and transfer case. While I was pulling back into my drive way. Which by tyhe way isw gravel and is on a 8 degree angle. I was about half way up and I hearda pop and the front axle did not work any longer. My question is what could I have broke? I looked up the breakdown of parts and I can not figure it out. I might just have to wait until I tear it apart. Thanks for the help.
frankenstienCJ is offline
post #2 of 9 Old 09-10-2011, 06:31 AM
mopar346
Is there any noise now when driving? 2WD? 4WD? Turning? Backing?
I am assuming you were in 4X4 at the time due to the comment about the front axle stopped working. Are you sure it's the T-case? Usually when turning in 4X4 the front axle binds, depending on the condition of the front and tire size it could have popped something in there. put the T-case in 4 high jump under the Jeep and see it the front shaft will turn by hand if it does then it is in the case, if it doesn't then it's in the axle. To test the axles jack up the front (secure on Jack stands if you go under it-legal statement you know), while still in 4WD and with the hubs locked spin one tire if the other does not turn then there is a disconnect, ie something broke. If you hear a gravelly sound when turning is in the carrier, if there is no distintive noise it's probably an axle. If no noise grap the other tire and spin it, the tire with the least resistance is probably the one with the brokenn axle. I am again, assuming the rear is pulling so we know it not the tranny, that would really only leave the front drive gear and output shaft (in general, don't know a 20 and am not looking at the schematic).
It is also possible that it popped out of 4WD and the shifter linkage got torqued and the inards are fine, it's just in the linkage.
Careful your character's showing
mopar346 is offline
post #3 of 9 Old 09-10-2011, 08:33 AM
Stumpbumper
You maytr have not been all the way in gear. Transfercase shifter linkage may be worn and not letting you completely shift. I would check this out before ripping something apart.
1984 CJ7, 258..HEI..MC2100, T176/D300, D30/M20 lockers, lift, warn winch!
"When in doubt! Gas it out!"
Stumpbumper is offline
post #4 of 9 Old 09-10-2011, 10:00 AM
jeepwhore
There are only a few components in the front axle itself that could be the culprit. But first do as suggested and make sure it didn't just kick the t-case out of 4H (which I assume you were driving in). Have you recently added a body lift or made any modifications? Were there any other sounds coming fromt the front after the initial "pop"?
Beyond that I'd check the easy stuff first. Give the axle shaft u-joints a visual inspection to make sure they are in tact. Then put it in 4wd, lock the hubs and try and turn the axle shafts by hand at the steering knuckle. If they can't be turned I'd say the lockouts and front gear set are probably okay (provided no other horrible noises were coming from the front) and would start looking to the t-case for answers. Keep it in 4wd, unlock the hubs and try and turn the front DS by hand. If it turns it's time to pull the t-case and open it up. If it doesn't turn maybe the driveshaft itself has failed in some manner. If not I guess your back to square one and will have to start tearing things apart one at a time to find the issue.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #5 of 9 Old 09-10-2011, 04:39 PM Thread Starter
frankenstienCJ
1978 CJ7
Ok today I checked the linkage. Found nothing there. a little to much wear for me but other than that it is all there. I did not have time to jack it up and check axles and the rest. I did get it out on the road so 2wd works and there is no noises. I do have to change the ball joints. I am going to take it over and get it up on a lift to verify the rest. Thank you all for the help. I will update later on what I find.
post #6 of 9 Old 09-10-2011, 05:03 PM
jeepwhore
You don't need to put it up on a lift to verify the things mopar and I suggested. Simply having the hubs locked with all 4 tires on the ground and trying to turn two driveline components with the t-case in 4wd will answer most of the questions. Less than 5 minutes and you should be able to at least narrow down the suspect list.
post #7 of 9 Old 09-10-2011, 07:46 PM
lucdog
lucdog's Avatar
1980 CJ5
Were you In 4, low or high, when this happened.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #8 of 9 Old 09-11-2011, 08:27 PM Thread Starter
frankenstienCJ
1978 CJ7
I was in 4 low. Going slowly up the drive way in reverse.
post #9 of 9 Old 09-11-2011, 08:41 PM
lucdog
lucdog's Avatar
1980 CJ5
It may not have been completly in 4 low. I, and others here would tell you a Dana 20 will work in 4 low, with just the rear axle, because of wear.
I'm betting this is the case with yours. Have you changed to a new shifter boot? Try again making sure the lever is all the way back.
The first time this happened to me, I was sure something broke.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
258 I6 Trouble WPM Jeep CJ Forum 9 03-19-2010 06:00 PM
cj5 trouble 8balls12 Jeep CJ Forum 4 10-15-2009 01:16 PM
Tie rod trouble zillla Jeep CJ Forum 8 07-07-2009 10:31 PM
Still having trouble DannibusX Jeep CJ Forum 7 01-21-2008 04:54 AM
Transfer case trouble? fireboy283 Jeep CJ Forum 4 05-22-2007 04:07 PM
