Transfer case:: Twin stick question - JeepForum.com
post #1 of 22 Old 04-16-2013, 10:25 AM Thread Starter
Tyger78
I'm looking at buying an 83' CJ-7, it has the 258 and Automatic trans.
Can I put a twin stick transfer case on it? The only thing coming up from the floor is the single transfer case shifter and the transmission shifter is on the column.
I've done lost my mind...... mind.... mind.... mind..... mind..... what a silly word.
Tyger78 is offline
post #2 of 22 Old 04-16-2013, 10:28 AM
Coiz
1979 CJ7
With a twin stick you don't replace the entire transfercase. You replace the single shifter with a dual shifter.
Mike
Coiz is offline
post #3 of 22 Old 04-16-2013, 10:38 AM
mike_bfdr
1981 CJ8
mike_bfdr is offline
post #4 of 22 Old 04-16-2013, 10:58 AM Thread Starter
Tyger78
I'm not a mechanical genius... but just replacing the shifter with 2 shifters makes no sense to me.
I'll check out those links, thanks.
Tyger78 is offline
post #5 of 22 Old 04-16-2013, 11:02 AM Thread Starter
Tyger78
Oh wow... Yeah, just saw that one for the dana 300.... It said you could choose between high and low, but can you choose "neutral" too?
Tyger78 is offline
post #6 of 22 Old 04-16-2013, 11:10 AM
mike_bfdr
1981 CJ8
ok this should help
http://www.pirate4x4.com/forum/jeep-...t-pattern.html
MY BUILD-----> http://www.jeepforum.com/forum/f22/81-jeep-scrambler-3-link-1507615/
post #7 of 22 Old 04-16-2013, 11:12 AM
CSP
The idea is to have one shifter for the front axle's output and one for the rear axle's output. This allows you to have the front in neutral and the rear in low range.
CSP is offline
post #8 of 22 Old 04-16-2013, 11:23 AM Thread Starter
Tyger78
OK... thanks.
So I took a look at that picture. I didn't know it was as easy as just changing the shifter into a dual shifter. I thought you had to have a special transfer case such as an Atlas II.
Looking at that picture, it seems as though they made it really confusing for such an easy operation. One side is labeled High, Neutral, Low, then the other side is labeled 4wd high, 2wd, 4wd low.......
I would have tried to explain it as Rear and Front.................. High, Neutral, Low............ am I correct? or am I losing my mind?
Tyger78 is offline
post #9 of 22 Old 04-16-2013, 11:29 AM Thread Starter
Tyger78
One more question, sorry for my squishy brain. This is a 258 with the automatic transmission. Anybody know what Transfer Case came stock? I'm in Iraq and can't physically look at it and my search results just come up with info on the transmission instead.
Tyger78 is offline
post #10 of 22 Old 04-16-2013, 11:36 AM
CSP
Ignore that picture as it is confusing. Refer to the other pictures at the start of that thread. Each stick has low range all the way forward, neutral in the middle, and high range all the way back. I would have labled that diagram like you would have.
Any '80-86 CJ came with the Dana 300 transfer case.
CSP is offline
post #11 of 22 Old 04-16-2013, 11:46 AM Thread Starter
Tyger78
Okay... I made a new diagram and got rid of those useless confusing cross lines.
Here we are:
Tyger78 is offline
post #12 of 22 Old 04-16-2013, 11:48 AM
mike_bfdr
1981 CJ8
i want to say the trans is 999 and the t-case is a dana 300
post #13 of 22 Old 04-16-2013, 11:51 AM Thread Starter
Tyger78
I meant the mechanical part of just changing the shifter. For some reason I thought you actually had to change the whole transfer case. I love the option of choosing between front/rear. I've always wanted that but thought I had to shell out some big money to change it. I can't wait.
Tyger78 is offline
post #14 of 22 Old 04-16-2013, 11:54 AM Thread Starter
Tyger78
Thanks for the info on the models. I had one many moons ago in High school as one of my first jeeps, but I only fixed what broke every week. I never did any major changes or upgrades. Is that transmission good in your eyes? I won't be doing rock crawling or anything, I'm going to turn it into my daily driver. Pretty much a beach comber.
Tyger78 is offline
post #15 of 22 Old 04-16-2013, 12:33 PM
John N
1981 CJ8
It's a good medium duty trans and should hold up fine. I have one in my Scrambler with a D300 AND twin sticks..
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
