My CJ has the stock 304 (just added Howell FI) and 3 sp transmission. The differentials are all stock as well.
I'm not sure which transfer/ transmission is stock but 4 low doesn't have a low enough gear ratio for climbing steep hills at slow speeds.
I want to install something that allows me to drive my jeep on the highway at speeds above 50 MPH and have the ability to climb steep hills at extremely low speeds.
My brothers 2005 Rubicon has great gearing for those extra steep hills. In 4 low, you drive up anything with the jeep just idling.
Try the Wanted Forum here on JeepForum first next time (as I'm sure it won't be the last time you need something for your CJ). I'm sure that the unit form Novak will be sweet, but there is a large number of CJ owners that reside here and many of them have parts. :thumbsup:
Be sure and research this swap thoroughly before you buy a transmission. There are several versions of the T18 and only a couple are worth swapping into your CJ.
Just got off the phone with the guys at Novac. I'm boxing up and sending my transfer case to them on Monday. They are going to rebuild my transfer case with a few Novac goodies and mate it to a new T18A.
They will ship everything back to me bolted together ready for install in 14 days.
Not bad for around $1700
you have three choices (more really). Do a Teralow 3:15 kit for about $850. Your drive shaft won't have to change. This will do nothing on the highway. Do a Ford T18 conversion which will run $250 for the tranny, $500 for the Novak kit, and another $200 on driveshaft lengthing/shortening. Or do a J=truck T18 which will require a PartsMike short shaft kit ($200) and the driveshafts ($200). I did the Teralow and J truck T18 in my old rig. The Teralow will be enough for most. The T18 only will be a little lower. Highway will require axle regear. You are probably 3.54. If you have over 33s you'll want more gear.
Related Threads
Jeep Enthusiast Forums
18.5M posts
727.5K members
Since 2000
