transfer case the same for automatic and manual transmissions? - JeepForum.com
post #1 of 6 Old 05-03-2016, 12:48 PM Thread Starter
weezaanna
Hi all,
Just starting conversion project for 1998 Wrangler TJ from standard transmission to automatic transmission. Is transfer case the same for standard as for automatic?
Also, we are looking for a good, used automatic transmission (rebuildable unit) with shifter and so forth. And, once the conversion is completed, husband will rebuild the manual transmission and it will be for sale. Anybody want to trade an automatic for a standard trans?! (He rebuilt transmissions professionally for 20 years.)
Thanks!
Weeza Anna
weezaanna is offline
post #2 of 6 Old 05-03-2016, 03:46 PM
jeep_boy02
1980 CJ7
Wrong section, you'll need to move your post to the TJ forum, this is the CJ one, but yes the 231 in TJs(also XJ and LJs) were same whether behind an Auto or manual IIRC from 1996 to 2006, unless it was a rubicon and then it is a 241OR with different gearing.
jeep_boy02 is offline
post #3 of 6 Old 05-03-2016, 04:17 PM
Fourtrail
1974 CJ6
Not quite, the ones behind the AX-5 were 21 spline and the some had longer input shafts than others with the 23 spline input.
http://www.novak-adapt.com/knowledge...g-input-gears/
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #4 of 6 Old 05-03-2016, 08:33 PM
CSP
TJs never had the AX-5.
CSP is offline
post #5 of 6 Old 05-04-2016, 04:06 AM
Rebel442
The 4 bangers did.
From our own FAQ's
http://www.jeepforum.com/forum/f9/st...1/#post4118380
It Wouldn't Be A Project If Everything Worked Right.
Rebel442 is offline
post #6 of 6 Old 05-04-2016, 09:24 AM
CSP
Interesting. I thought the AX5 was only used on 4cyl YJs.
Shows how much attention I pay to later models.
CSP is offline
automatic transmission , conversion , transfer case
