transfer case problem? - JeepForum.com
post #1 of 7 Old 01-12-2009, 06:54 AM Thread Starter
vmaxup
1979 CJ7
Ok my 79 cj7 I got about 4 months ago. Finally driving it around after getting some new swamper shoes for it.
Not going far from home yet. Still fixing little things...
Yesterday I thought I would try out the 4 wheel drive.. Got out locked the hubs.
Then put in 4 low... Sounds like something is broke after I steped on the gas. It worked before. Its works in 2wd fine.. and it sounds like broken gears or some thing. Drive shaft is turning.
I then unlocked the hubs and left in 4wd still sounds horible. Put it in 2wd and all is good.
This jeep had a 304 from factory. It had a 6 put in somewere along its life along with the 5 speed and transfer from the 6 cylinder swap.. It now has the 304 in front of the 5 speed.
So I know the transfer case is a big iron unit, I believe a 200 hundred.
So my question is were to go from here. Maybe take the front dif cover off and take a look first? Just to make shure its not the front end. I will do this tonight.
Can I rebuild that Transfercase myself? Is there any good sugestions for this T case... Also if im going in there Can I lower the gears?
vmaxup is offline
post #2 of 7 Old 01-12-2009, 07:12 AM Thread Starter
vmaxup
1979 CJ7
Sorry 300 T-case
vmaxup is offline
post #3 of 7 Old 01-12-2009, 09:00 AM
No_Bs
1977 CJ5
Take the diff cover off, and check it out. It probably needs new oil anyways. If the gears look good, also check for a broken axleshaft before blaming the Tcase. The 300 is nearly indestructible, but the Dana 30 is not.
1977 Cj5, 258, T-18, 2.46:1 Dana 20, 2.5" BDS lift, OBA, 38.5's. Chevy 60 frt, 14b Rear, Full hydro, 102"wb, full DOM cage.
No_Bs is offline
post #4 of 7 Old 01-12-2009, 09:18 AM
foggybottombob
In another week or so, I'm going to have an extra set of Dana 300 internal's. So if you need any Dana 300 stock gears, let me know.
foggybottombob is offline
post #5 of 7 Old 01-12-2009, 07:22 PM Thread Starter
vmaxup
1979 CJ7
foggybottom....are you putting in lower gears? were you getting the stuff..
Put up on jackstands sounds horrible.. There is a cover on rear of t/case at bottom. can you see bad gears in there also.. its a pretty big cover Ill pull front dif cover tomorrow night.
vmaxup is offline
post #6 of 7 Old 01-12-2009, 09:21 PM
foggybottombob
I am putting in LowMax gears from JB Conversions. But my case was cracked so I had to buy another t-case to have a case to work with. I have stock gears for D300's coming out my ears now.
post #7 of 7 Old 01-13-2009, 06:22 AM Thread Starter
vmaxup
1979 CJ7
send me your phone number
vmaxup is offline
transfer case problem (leaking) Brg0012 Jeep CJ Forum 5 11-25-2009 08:54 PM
Transfer case problem! kellyhance Jeep CJ Forum 1 06-22-2007 10:10 AM
Transfer case slip problem!!! TheDuke276 Jeep CJ Forum 4 04-04-2005 08:26 AM
'75 CJ Transfer case problem Axiom Jeep CJ Forum 4 02-20-2005 08:11 PM
HELP!! transfer case problem royleeair Jeep CJ Forum 3 02-13-2005 03:36 PM
