Transfer case identification from shift pattern - JeepForum.com
post #1 of 13 Old 05-27-2011, 09:07 AM Thread Starter
LordSul
1975 CJ5
Im learning new stuff about my jeep every day, and its amazing me everytime, my transfer case is so strange I couldnt find a similar shift pattern as mine, on the net.
I have 2H and 2L 4H and 4L and N.
Dana 18?...maybe? how come its on my 232 engine...
Every idea counts, thanks.
76' Jeep CJ7, AMC 232, Weber Carb 32/36, TeamRushed, MSD6, 33" Maxxis Mudzilla
"Tear down the walls of Nicosia"
LordSul is offline
post #2 of 13 Old 05-27-2011, 09:11 AM
jcal73
jcal73's Avatar
2015 JK Wrangler
Do you have two sticks?
Jeff
Our Jeep Links
jcal73 is offline
post #3 of 13 Old 05-27-2011, 09:20 AM
MoC
Is it labeled as 2L or is that a spot you found while shifting? Pictures of the tcase would help. There should also be a casting number / tag on it that would help as well.
MoC is offline
post #4 of 13 Old 05-27-2011, 09:32 AM
CSP
A '76 would have come with a Dana 20. With wear in the shifting linkage you can get to 2L between Neutral and 4L. There are two shift rods which the linkage attaches to, one for each axle. With the slop in the linkage the rod for the rear axle will engage low gear while the rod for the front axle is still in neutral.
CSP is offline
post #5 of 13 Old 05-27-2011, 09:35 AM
lucdog
lucdog's Avatar
1980 CJ5
If the rear axle pumpkin is not offset to the passenger side, its probably not a D-18. The D-18, rear output is more toward the passenger side, Dana 20 and 300 are centered rear outputs.
It would help if you started with the lever position closest to the firewall, and listed the positions back toward the seats
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #6 of 13 Old 05-27-2011, 09:35 AM
MoC
Thats why I asked him if it was labeled as 2L, thinking the same thing.
MoC is offline
post #7 of 13 Old 05-27-2011, 09:52 AM
CSP
None of the stock CJ transfer cases would have been labeled with 2L, even the Dana 18.
The twin stick Dana 18 had one shifter for high/low range and the other engaged/disengaged the front axle. You couldn't engage low range unless the front was engaged first also.
CSP is offline
post #8 of 13 Old 05-27-2011, 12:58 PM Thread Starter
LordSul
1975 CJ5
Mine never had a shift pattern on the knob, I discovered this by trial, I tried every position, front wheel hubs at free position, and had a friend looking at the front and rear shaft turning.
After that I re checked by turning the wheels....Ill send some pics tommorow.
My jeep is big crossbreed, the VIN on the plate says 75 CJ5, but clearly the frame is not a cj5, measured it, tub is cj7. And so on...so dont count on it as a regular cj7, this transfer case may even be from willys....heres the link to that thread,
http://www.jeepforum.com/forum/f8/un...-model-871915/
LordSul is offline
post #9 of 13 Old 06-02-2011, 02:40 AM Thread Starter
LordSul
1975 CJ5
Ok Ive checked my shift pattern again, it goes like this
from top to bottom: 4H - 2H - N - 2L - 4L
Rear diff looks centered. but the TC looks towards passenger side.
Heres the pic
Uploaded with ImageShack.us
LordSul is offline
post #10 of 13 Old 06-02-2011, 03:18 AM Thread Starter
LordSul
1975 CJ5
I coulndt read the numbers on the case but I think I saw the DANA sign in a trapezoid shape.According to my research, this is most probably DANA20, with removed "shifter rail interlock pin", which I read, adds a 2wd L function. But again, this applies to DANA300 too...!
My TC has one shifter stick, could it it converted to single stick from twin stick? Or a single stick DANA300, they both look exactly the same
LordSul is offline
post #11 of 13 Old 06-02-2011, 09:26 AM
CSP
It's a Dana 20. I can see the tailhousing is cast iron (Dana 300 tailhousing is aluminum) and the speedo cable location is consistent with a Dana 20.
As I said earlier, slop in the shifter linkage allows it to go into 2low. Lots of older Dana 20s do this, inluding two that I have. No need to remove any interlock pills. Removing interlock pills allow front wheel drive, low range anyhow.
CSP is offline
post #12 of 13 Old 06-02-2011, 02:25 PM Thread Starter
LordSul
1975 CJ5
Thank you! All sorted out.
LordSul is offline
post #13 of 13 Old 11-06-2014, 08:10 AM
tshade
On my 73 cj5 TC shift knob has it labeled 4H 2H N 2L 4L
tshade is offline
Transfer case shift pattern.. AzSandSlinger Jeep CJ Forum 5 08-14-2017 08:11 PM
Model 20 Transfer Case Shift Pattern BeesJeep Jeep CJ Forum 2 04-25-2009 08:05 AM
transfer case shift pattern 3j972 Jeep CJ Forum 10 08-02-2007 01:47 AM
t-case shift pattern 1990JEEPXJ Jeep CJ Forum 7 02-04-2007 03:06 PM
Transfer case shift pattern? CJerseyboy Jeep CJ Forum 4 11-12-2004 02:21 PM
