transfer case id ? - JeepForum.com
post #1 of 11 Old 02-13-2015, 10:08 AM Thread Starter
dl011
1983 CJ7
transfer case id ?
trying to see if someone could help me id the transfer case in my 1983 cj7. 6 cyl. 258. 4 speed trans. dont know what transmission? transfer case has 2 shifters.
thanks.
dl011 is offline
post #2 of 11 Old 02-13-2015, 10:21 AM
AZ93YJ
thanks.
You got a dana 300 right there.
AZ93YJ is offline
post #3 of 11 Old 02-13-2015, 10:21 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Dana 300. Same as came on all '80s CJs.
Matt
Matt1981CJ7 is offline
post #4 of 11 Old 02-13-2015, 10:26 AM Thread Starter
dl011
1983 CJ7
thanks for the info
dl011 is offline
post #5 of 11 Old 02-13-2015, 11:42 AM
texasdave
texasdave's Avatar
1980 CJ7
PO or someone did a twin stick mod on it.
texasdave is offline
post #6 of 11 Old 02-13-2015, 12:30 PM
AZ93YJ
It's also labeled 300
AZ93YJ is offline
post #7 of 11 Old 02-13-2015, 01:11 PM
CSP
There are also Dana 20s with 300 cast into them. The aluminum rear output housing is a dead giveaway that it's a 300 though.
CSP is offline
post #8 of 11 Old 02-13-2015, 01:41 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Of course it could be a dana 300 even with a cast iron rear output housing.
John Strenk is offline
post #9 of 11 Old 02-13-2015, 04:19 PM
CSP
Did the 1980 CJ D300s have a cast iron rear output? I know that none of longer vesions did.
CSP is offline
post #10 of 11 Old 02-13-2015, 06:21 PM
John Strenk
1976 CJ5
Yep
post #11 of 11 Old 02-13-2015, 07:07 PM
CSP
I thought so, but wasn't sure. That's the same output that the D20 uses. I knew the speedometer drive was on the same side, but didn't know they were cast iron.
CSP is offline
