trans swap - JeepForum.com
post #1 of 2 Old 08-30-2002, 10:21 AM Thread Starter
stonechucker
trans swap
I currently have a CJ-5 with a 3-speed trans in it. I was wondering if there was enouph room in the driveline to fit a newer 5 speed T-5. I know that it will connect to the amc 304 with the correct bell housing, but the question is on the length of it.
stonechucker is offline
post #2 of 2 Old 09-01-2002, 02:05 AM
RODDOR
I put a T5 in a 1983 CJ5 with a 258 engine. You are left with about a 13 inch long rear driveline. If you have a lot of lift you will probably need to get a cv shaft because of the angle. I used a straight shaft on mine with about a 2 inch lift. I found a catalog that listed a spicer rear driveshaft showing the T5 as option for the CJ5.
RODDOR is offline
trans and TC swap ? jm708 Jeep CJ Forum 5 02-10-2010 06:04 PM
trans swap Hardy350 Jeep CJ Forum 0 12-24-2008 09:39 AM
Trans swap c17load83 Jeep CJ Forum 1 04-04-2007 01:56 AM
trans swap bigflatblack Jeep CJ Forum 9 03-22-2007 12:44 PM
Need Help with Trans. Swap!! Robb Kiker Jeep CJ Forum 8 11-19-2004 10:17 AM
