trans input shaft lube? - JeepForum.com
post #1 of 4 Old 02-04-2013, 11:30 AM Thread Starter
shadoow
have got my trans out (T177) for rebuild. Am also changing out the throwout bearing and pilot busing. I've read on these forums that the trans input shaft should be lightly lubricated. Was wondering if anyone has used a dry lubricant like slip plate. Seems it wouldn't have a tendency to collect debris as much as a grease would. What do you guys think??
shadoow is offline
post #2 of 4 Old 02-05-2013, 07:00 AM Thread Starter
shadoow
anyone ??
shadoow is offline
post #3 of 4 Old 02-05-2013, 08:16 AM
caseypotts
1980 CJ7
My clutch kit came with a very small amount of lube for this purpose. I used what came with the kit.
1980 CJ7 GM151 Bored out, Flat Top Pistons, Hedman Header, 2.5in Superlift springs, Extrem Shocks' 31 10.5 Mastercraft Courser MT tires on Allied MockLoc rims, Blazer heater upgrade.
Her Ride
2003 Liberty Renegade
caseypotts is offline
post #4 of 4 Old 02-05-2013, 01:38 PM
agear
I used a light grease. Which is what my automotive technology text book said to use. You don't want to use too much because it will sling onto the clutch disc and that's not good. I also heard that you can use antiseize and I think the reasoning behind that is that it will not sling off. But like I said I stuck by the book.
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
