trans fer case - JeepForum.com
post #1 of 3 Old 09-12-2011, 11:40 PM Thread Starter
lgrosskopf
1985 CJ5
trans fer case
my dana 20 transfer case has twin stick setup on it the prob i have is thtat there is no detent present in the rear axle hand le 4 4low so it pops out but the front axles clicks in 4 low and holds fine transfer case is all new inside as well and the rear axle shiffter does click in hi range and neutral so im stumped.....
lgrosskopf is offline
post #2 of 3 Old 09-13-2011, 12:48 AM
BagusJeep
1981 CJ7
They routinely stick in 4Lo, it is a feature. You need to back up a bit until it goes into neutral.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is online now
post #3 of 3 Old 09-13-2011, 04:18 AM
mopar346
Welcome to the forum, lot of knowledgeable people that are willing to help in a clean environment.
I believe he is having a problem with it POPPING out of 4 lo not having problem GETTING it out of 4 lo. Not familiar with the inards of a 300 but if I were looking I woudl look for the syncro/engagement hub and the gear that it locks onto. I would also check the adjustments if any of the shifter, even if it out of adjustment chances are it has damaged something internally at this point. It is my understanding that they are very durable units.
Careful your character's showing
mopar346 is offline
New Trans and transfer case JJHearn Jeep CJ Forum 3 04-19-2011 11:47 AM
CJ7 trans and t-case swap joker3266 Jeep CJ Forum 1 11-02-2009 08:52 AM
After trans case drop...??? JeffMcBusa Jeep CJ Forum 2 03-05-2009 08:43 PM
trans case? smitch Jeep CJ Forum 5 06-28-2006 04:31 PM
cj trans case 85xj350 Jeep CJ Forum 0 09-25-2005 12:29 PM
