Quantcast trans ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > trans ?
East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.Great deals on Rigid Lights. SR and E series
Old 04-03-2007, 03:10 PM   #1
bigflatblack
1988 XJ Cherokee
trans ?
i have a 84 ford ranger 4x4 with a five speed....my ?...is can that bolt up to the back of a 258 in a cj7....if it does will it be too weak for the 258 and also will the dana 300 work with it?
bigflatblack is offline   Reply With Quote
Old 04-03-2007, 04:25 PM   #2
bigflatblack
1988 XJ Cherokee
anyone??
Old 04-03-2007, 05:29 PM   #3
bdmonist
WTF is that?
bdmonist's Avatar
What's the tranny and what is it behind now? Go here and see what they have:
www.novak-adapt.com
You can usually make anything work, the question is - is it financially justified to do so?
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift.
AMC 20 Write Up
In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles
Coming Soon - CV Shafts, Welded Tubes, trusses
bdmonist is offline   Reply With Quote
Old 04-03-2007, 05:31 PM   #4
bigflatblack
1988 XJ Cherokee
www.novak-adapt.com
well for me i could afford it....i have a ranger that has a shot 2.3 and its 4x4 with a 5spd...thats why i am asking about it.....it wouldnt cost to much to do it if its swappable....so i just need help figuring up my parts list
Old 04-03-2007, 05:38 PM   #5
bdmonist
WTF is that?
bdmonist's Avatar
The first thing you need to know is what the tranny is and if it's medium or light duty. Some on here may know off the top of their head, I do not. If it's medium duty, you would be fine. ONce you know the tranny, you need to research here and on the novak / AA sites to see what adapters you need to make it work. If you need an adapter for the engine and the TC, you are looking at upwards of $1000 and it probably be better to buy a different tranny. You need to consider you entire drivetrain length - Future vs Present, and determine if you will need to buy new driveshafts - More $$$ - Take it step by step, find out what you have and go from there. The guys on here will help you out a lot if you have some specific swap questions, it's tough if we don;t know what you have and what you want.
AMC 20 Write Up
Old 04-03-2007, 05:43 PM   #6
bigflatblack
1988 XJ Cherokee
i know that i have a post on a ford forum trying to get the info asap...i just was asking incase anyone on here has done it ....as far as the drivetrain length now my cj has an auto it in and it would be better as a stick...thanks for trying to help me though
Old 04-03-2007, 05:52 PM   #7
bdmonist
WTF is that?
bdmonist's Avatar
Auto to standard is a whole other swap in its self
AMC 20 Write Up
Old 04-03-2007, 05:56 PM   #8
bigflatblack
1988 XJ Cherokee
i know thats why i am trying to figure if it will work....i hate my auto and want a stick and hell i already have that 5spd laying around so....
Old 04-03-2007, 05:57 PM   #9
Bard
Nope, don't think it is worth your time or money to swap it. Ford made a few 5 speeds for rangers up to 85 and then made the 4 speed optional. They were light duty. I would rebuild your tranny. The amount of work it will take to be a manual is alot to gather parts, clutch linkage, pedal assembly, flywheel, driveshafts, etc, etc.
Live with it and when you have the funds, you can do it the way you want to. In my opinion, the easiest way is to buy a parts rig (rust bucket) with a good running drive train. Take what you need, sell the rest and try to break even.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline   Reply With Quote
Old 04-03-2007, 07:06 PM   #10
KrazyGimp
1982 CJ5
Well if the info in your profile is correct it looks like you are running a Dana 300 t-case, correct? If so, and you ARE set on a manual swap, I would recommend looking for a T-176 from a CJ. They are a well built 4 speed manual that will bolt straight up to your engine and t-case (read: save $1,000). At that point you would be looking at new driveshafts at the very least. You could probably mod your current skid plate to mount to or buy one from a CJ that came with a 258/t-176 combo and it should bolt right up.
Then you are into the issue of swapping the entire pedal assembly for the clutch. Next you need to probably fab up brackets to swap the clutch linkage in among other little things. Don't know if any of this helps though....
1982 CJ-5 Laredo 258, T-176, D-300
1972 240z in pieces...
Originally Posted by BESRK
...that's why you push in that little nipple (hehe.. I said nipple on the internet :D )
KrazyGimp is offline   Reply With Quote
Old 04-03-2007, 08:11 PM   #11
Rob55
I have most all of the manual parts I swapped out of my CJ when I changed over to the 700r4. (T-176, bell housing, flywheel, pressureplate, drive shafts, swing pedals, shifter, and a never installed hydraulic clutch kit) It was all backed up by a Dana300 (which I kept). All of it worked fine at the time I pulled it out and there are some small parts I don't have, but I can let you have it for $500. I am not too far from you, about 85 miles. You would need a clutch fork, shifter pins, pedal springs, brake swith, small bits...
1984 CJ7, 258, MPI, 4.0 head, Borla, 700r4, amc20 (detroit), Dana 30 (OX), 4.56 gears, Warn Hubs, Dana 300 with 4:1, 4.5 RE lift with 1" body, Bilsteins, dual battery, PS, PB, full cage, two dogs in the back....
Rob55 is offline   Reply With Quote
Old 04-04-2007, 12:26 AM   #12
bigflatblack
1988 XJ Cherokee
i have everything for it i just want to know if it will work or not
Old 04-05-2007, 11:57 AM   #13
bigflatblack
1988 XJ Cherokee
anyone ever doe this swap??
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
