Tranny Replacement - JeepForum.com
post #1 of 6 Old 12-05-2002, 04:27 PM Thread Starter
icarus00000
Tranny Replacement
I want to replace my 4 speed SR-4 tranny with a T5 tranny. Would this just go right in with ease ? If not, what changes need to be made ?
The jeep is a 86 CJ7, with 4 cyl motor.
Thanks
icarus00000 is offline
post #2 of 6 Old 12-05-2002, 06:59 PM
Mud Dobber
I've been curious about this same swap and wonder if all T-5s are the same?
Mud Dobber is offline
post #3 of 6 Old 12-05-2002, 08:26 PM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
Cool
All Jeep T-5's are the same. They are not the same as the ones in Mustangs.
Not sure if the SR-4 uses the same bellhousing.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #4 of 6 Old 12-05-2002, 09:38 PM Thread Starter
icarus00000
So, I can unbolt my 4 speed and bolt up the T5 then ? Flexplates the same ?
post #5 of 6 Old 12-05-2002, 10:46 PM
only in a jeep cj
Two types of bellhousings are used in those years of CJ's. One fits the T-176, T-177, and T-150. The other (the one you have) fits the SR-4, T-4, and the T-5. Make sure your input shaft has the same spline count (either a 10 or 14) or you can change the clutch disk to match. This would also be a good time to check/replace the clutch. I have the T-5 myself and love the 5th gear overdrive.....my 258/3.31's/stockish tires can use 5th from 45 to 100 mph. Can't imagine being on interstate with out it.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #6 of 6 Old 12-06-2002, 05:09 PM Thread Starter
icarus00000
It does suck without that overedrive gear, thats for sure. Even the 4 banger screams SHIFT ME, SHIFT ME.
Thanks for the addtional info. Answered my questions
Tranny Replacement - Choices? cw4stein Jeep CJ Forum 9 10-20-2009 09:39 PM
T-5 replacement tranny dave_dj1 Jeep CJ Forum 3 08-21-2006 04:11 AM
Tranny replacement for a 258 Brian4.2 Jeep CJ Forum 4 11-26-2005 08:33 AM
replacement tranny suggestions oldhokie Jeep CJ Forum 13 03-23-2005 04:44 AM
CJ-7 1980 tranny help!! Tranny guys in here! Cherokeester Jeep CJ Forum 3 02-24-2005 03:44 PM
