Tranny questions - JeepForum.com
post #1 of 3 Old 01-06-2002, 07:07 PM Thread Starter
West
Post Tranny questions
My Jeep (84 CJ-7with a 258) has a 4 speed transmission with an iron case. Thats about all I know about it at this point. i'm kind of partial to 5 speeds for highway driving. Will a T5 bolt in without changing other things like flywheel, clutch, clutch linkage? Does anyone know the gearing of these 2 trannys? Any opinions on whether the swap is a good or bad idea? I'd be doing the work myself so the tranny would be the major expense.
West is offline
post #2 of 3 Old 01-06-2002, 08:56 PM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
Cool
Ii you have a T-4, it's a direct swap. The probelm with the T-5 (and the T-4), is that it is a light-duty tranny, and many would not ever bother swapping it in. There are better options, even the AX-15, which was offered on some YJs, or the pricey NV4500, which will require lots of modification but will outlast the rest of the Jeep. Note, a World Class T-5 is a bit better, and is just a beefed-up verison of the T-5, so it will fit where a regular T-5 fits.
For T-5 ratios and everthing else you want to know about it:
http://www.off-road.com/jeep/tech/trans/t5.html
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #3 of 3 Old 01-06-2002, 10:00 PM
hamyscj
Post
If your tranny has an iron case then it is not a t4 or sr4. It might be a t176 or someone might have swapped in a t18. Either of those last 2 are a desireable trans. If it is a t18 look at the casting # on the side of the shift tower. It should start with 1301-something or another. Keep it if it is. Later, Hamy.
One Way Up Racing
Romans 10:9
hamyscj is offline
CJ5 Manual Tranny Questions CJ5Freak Jeep CJ Forum 6 07-23-2008 03:21 PM
Tranny Swap questions thedesertnomad Jeep CJ Forum 1 05-31-2006 11:18 AM
Tranny questions....help please.... opksjeeper Jeep CJ Forum 1 09-16-2005 12:37 PM
More CJ Tranny Questions had Jeep CJ Forum 2 05-07-2004 11:10 PM
T 5 / tranny questions chuck86 Jeep CJ Forum 1 03-14-2002 04:57 PM
