Tranny question on 1964 CJ5 - JeepForum.com
post #1 of 6 Old 06-28-2012, 06:55 PM Thread Starter
stephenxchen
1964 CJ5
I am a new jeep owner. Bought this CJ5 a few months ago.
Everything is pretty much all stock, original.
Original F134 engine, original 3 speed transmission.
My question is:
When I am down shifting to 1st gear, I have to come to a complete stop in order to do that, other wise it will be grinding.
I can down shift to 2nd gear fine.
Is this normal? or does it mean some part needs to be fixed?
Please help.
Thanks
stephenxchen is offline
post #2 of 6 Old 06-28-2012, 07:38 PM
wblackm
Yes this is normal. 1st gear is not synchronized on the majority of the early transmissions.
wblackm is offline
post #3 of 6 Old 06-28-2012, 08:33 PM Thread Starter
stephenxchen
1964 CJ5
thanks for the reply.
is there a way to "synchronize" the 1st gear?
post #4 of 6 Old 06-28-2012, 10:26 PM
Jack61
1981 CJ7
Nope no way to add a sychro to 1st gear in the tranny you have
Jack61 is offline
post #5 of 6 Old 06-29-2012, 12:27 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Start practicing "double clutching". As you go from 2nd to first, let the clutch out in neutral while revving the engine a little. This will get the gears spinning in the transmission. Then dis-engage the clutch and try to get the trans into 1st. Start practicing this while moving slowly. Once you get the feel for the engine RPM's matching the trans RPM's, you will be able to get into first with little or no grinding while on the move.
jeepdaddy2000 is offline
post #6 of 6 Old 06-29-2012, 10:37 AM Thread Starter
stephenxchen
1964 CJ5
thanks guys, I will try double clutching then.
Cj-5 1964 - engine/tranny swap advice whwm01 Jeep CJ Forum 19 11-21-2012 04:27 PM
1964 cj dizzy gpulse@centuryt Jeep CJ Forum 1 05-17-2012 08:26 AM
1964 CJ5 Seat ? weedy Jeep CJ Forum 1 05-13-2012 11:01 AM
FYI: saw this for sale 1964 CJ5 rameyt2000 Jeep CJ Forum 0 09-18-2010 07:44 PM
Value of 1964 CJ5 haighr Jeep CJ Forum 2 07-30-2009 08:39 AM
