Tranny pictures does this tranny look fine? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Tranny pictures does this tranny look fine?
07-15 jeep JK Spare Tire Carrier Delete PlateCorbeau Seats & Harness from CCOR!Win a $250 Gift Card to ZoneOffroad.com - 4th of July Face
Unread 02-16-2013, 05:01 PM   #1
Tigerpaw
1983 CJ8
I have a tranny i pulled several years back from my scrambler i though the syncro's were bad but now i can't tell by looking what do you all think see pic's attached. Does this tranny look okay.
Tigerpaw is offline   Reply With Quote Quick reply to this message
Unread 02-16-2013, 05:20 PM   #2
82JeepCJ7
1982 CJ7
Is it my eyes
82JeepCJ7 is offline   Reply With Quote Quick reply to this message
Unread 02-16-2013, 05:24 PM   #3
cj5huntingrig
1974 CJ5
They are worn but they look okay. As long as you can't find any cracks.
If you are wondering if it will drive and shift like new then no. With that said, as long as your bearings are okay, you can probably put off a rebuild for a little while. Fill 'er up and go!
1974 CJ5 all stock except for Rocky Road SOA
Completely for hunting - not for show or rock climbing
cj5huntingrig is offline   Reply With Quote Quick reply to this message
Unread 02-16-2013, 05:28 PM   #4
Tigerpaw
1983 CJ8
lights or flash no chips yet
Originally Posted by 82JeepCJ7 View Post
Is it my eyes
Unread 02-16-2013, 05:55 PM   #5
Noplainsdrifter
1974 CJ5
It looks a little rusty, meaning the bearings could also bo rusty. If you are buying it, it better be cheap! If your going to run it, you might put a magnet in it, fill it, run it, then change out the oil and see what magnet catches. It is definently broke in!
It's a Jeep Thing, Chrysler Doesn't Understand!
Noplainsdrifter is offline   Reply With Quote Quick reply to this message
Unread 02-16-2013, 08:54 PM   #6
MoC
As far as the syncros & thrust washer go they wear by getting thinner so the only way to tell would be pull it apart and measure. However if you go that far might as well just replace them. I might be a little worried about the rusting on the gears having pitted and weakened the gear teeth. Hard to really tell without seeing it in person but this gear looks a little beaten up.
MoC is offline   Reply With Quote Quick reply to this message
Unread 06-09-2015, 01:37 PM   #7
Tigerpaw
1983 CJ8
MOC,
Do you know any tool rental stores that carry the pull to remove the bearings on a T176. I can't find a pull around here nobody has one. I think its a Pronto with extensions, unless you have a better idea. I'm in Gibsland, La. so Shreveport stores are close enough.
Thanks.
Unread 06-09-2015, 01:47 PM   #8
johninmichigan
1979 CJ7
Hard to tell without disassembling it but might be worth installing it and hoping for the best.
John in Michigan (Back in Horseheads NY) '79 CJ7, 2012 Chevy Malibu. 07 Nitro,
johninmichigan is offline   Reply With Quote Quick reply to this message
Unread 06-09-2015, 07:29 PM   #9
71-CJ6
1971 CJ6
I was expecting to open this and see a picture of Bruce Jenner... errr Caitlyn Jenner... tranny.
CJ6... the Original Unlimited.
71-CJ6 is offline   Reply With Quote Quick reply to this message
Unread 06-09-2015, 07:57 PM   #10
1949er
from what I see in the 3rd. from last pics. the syncro is gone , very little clearance between the engagement teeth of the gear and the syncro ring
1949er is offline   Reply With Quote Quick reply to this message
Unread 06-09-2015, 08:02 PM   #11
CSP
The thread is two years old. Someone bumped it for a completely different question instead of starting their own thread.
CSP is online now   Reply With Quote Quick reply to this message
Unread 06-09-2015, 11:15 PM   #12
only in a jeep cj
Thats funny^^^^^^^
I was just about to go off on am I the only one that sees the worn sychronizer teeth and all the debris in it? to add fluid and "run it" as is would mess it up even more.....
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now   Reply With Quote Quick reply to this message
Unread 06-24-2015, 05:22 AM   #13
Tigerpaw
1983 CJ8
Just finished having the tranny rebuilt thanks for the input.
