-   -   Tranny Mount (stabilizer side) for CJ7 (http://www.jeepforum.com/forum/f8/tranny-mount-stabilizer-side-cj7-20531/)
Jeep Daddy 10-10-2002 10:17 PM
The PO has a bunch of washers in the side tranny mount and I was wondering what is the proper adjustment or shimming of the stabilizer tranny mount?
For those that don't know what I'm talking about, the tranny has 2 mounts. One is in the center of the tranny that has 2 bolts going through the skid to the mount. The other one is on the drivers side to take up the engine torque. It has a stud that is nutted to the skid plate, two poly bushings above the skid plate, some washers, (that's what I'm not sure about), the steel tranny mount and a nut on that.
Anybody know the exact configuration for this? Please don't guess on this. I like to do things right, not Mickey Mouse.
only in a jeep cj 10-11-2002 02:37 AM
No Micky here as I replaced one a few hours ago with a clutch job. For your T5, use the reward most set of holes on the trans. The tricky part for some, is that the tourqe arm extends past the mounting surface of the tranny and sticks out (one hole worth) toward the frond driveshaft yoke. A bolt and nut attach the trans mount to the arm at this location. The 2 holes to use on the bottom of the transmission (to attach the mount and arm combo) is the center one (goes through the other side of mount and the arm, AND the drivers side (of the 3 holes) which will only go through the arm. This will leave the rest of the arm to stick out towards the drivers side to locate the stud. The bottom of the stud is bolted tight to the pan while the top part comtains the bushings on either side of the arm and a big washer and nut on top that is snugged down only to press everthing together some. Not major tight as some do it. The mistake that I have seen is that people leave the pan side of the stud loose and this wollows out the pan hole. The washers are on the top and bottom of the bushings only, while the bushing touch each other at the center......through the arm.
Bulletproofcj7 10-11-2002 05:45 AM
I know you dont want guesses but is it possable that the engine sits lower on the mounts on the passenger side ( unsure on the 258 mounts, but the 304 has slots for adjustment) causing the torque bushing on the drivers side to lsit higher and make space that was taken up buy shims/ washers?
You may want to try and rotate the motor in the mounts to bring that bushing closer to the pan.
just my 2cents
Jeep Daddy 10-11-2002 10:40 AM
Pic of Stabilizer bushing
Here's a pic of how I think it should be. I've been on 3 forums and have 3 different answers on how this should be. Can anyone tell me if they think this is right or not. The pic is of my skid mounted in a vise with my stabilizer bushing in the pic.
http://home.att.net/~realbud/wsb/med...9/site1022.jpg
MR.CJ-7 10-11-2002 04:41 PM
Thats what mine looks like.
Bulletproofcj7 10-11-2002 06:41 PM
That doesnt look right to me, There is a reason that bushing is two peices, it should isolate that metal mount. Otherwise it would be a one piece bushing.
Is there enough room to put another nut under the lower bushing to adjust the amount of slop?
Unfortunately i dont have mine in front of me to look at so im going from memory here.
RODDOR 10-12-2002 11:26 PM
Jeep Daddy your setup in your photo is wrong. Only in a jeep CJ gave the correct setup. One bushing needs to be on top of the metal channel and one needs to be underneath. I'm not a computer guy. But if you have a fax I can fax you an exploded view of a proper set up that I got from a dealership. There is also an old JP magazine artical that shows the same set up for the poly mounts that you are using. With some looking I can tell you what edition its out of or I can fax a copy of it to you. I found on mine that if you double nut the end that goes through the skid pan it won't come loose and waller out the stud hole.
Jeep Daddy 10-13-2002 12:30 AM
Some of you guys are right, some wrong. The ones that are wrong have it like me. The stabilizer arm is suposed to be sandwiched between the bushings and the short end of the stud through the skid plate. I just got back from a place that has about 15 CJ's on the lot and I looked under all of them. Even the automatic trans has it like that. I was a little surprised because it just doesn't seem to fit tight like I thought it should.
Oh well, I'll do it right and take someones advise to double nut the bottom one. The skid plate is wallered out a little and my old stud was toast.
Thanks again.
The time now is 09:41 PM.
