tranny help - JeepForum.com
post #1 of 11 Old 05-18-2002, 01:08 PM Thread Starter
KNIFE
Post tranny help
my 4 speed wont stay in reverce i have to hold it there and it still wants to pop out.i beleive its a borg warner my cj is a 81 with a 258 I6.the junk yard here has the same tranny i do they want 225 for it.what should i do
KNIFE is offline
post #2 of 11 Old 05-18-2002, 02:44 PM
nuzzy
Post
Do you happen to have a body lift or a dropped tranny or anything that might mess with the shifter itself. Sometimes with a body lift, the shifter hits the edge of the cut out sooner and thus, won't let you go all the way into gear.
Slaving away at JCR
nuzzy is offline
post #3 of 11 Old 05-18-2002, 03:24 PM Thread Starter
KNIFE
Post
i have a 1"body lift but it is fine.it is something inside the tranny thank nuzzy
KNIFE is offline
post #4 of 11 Old 05-20-2002, 12:00 PM
4wheeler4CJ
4wheeler4CJ's Avatar
Arrow
You could also have the SR-4 Junk tranny 4-speed. It was used behind some 258s that year, unfortunately.
4wheeler4CJ is offline
post #5 of 11 Old 05-20-2002, 01:01 PM Thread Starter
KNIFE
Post
WHY DO YOU SAY THE SR-4 IS A JUNK TRANNY AND WHAT CAN I REPLACE IT WITH THAT WILL MATCH EVERYTHING THANKS FOR YOUR HELP
KNIFE is offline
post #6 of 11 Old 05-21-2002, 06:53 AM
4wheeler4CJ
Arrow
The SR-4 is a very light-duty tranny made by Ford that Jeep used for a few years in the early 80s, unfortunately. It was used mostly behind the GM 151 4-banger, but was also put behind some 258s for some reason. It was OK behind the 4-banger as long as it wasn't beat-on, but usually wore out quickly behind the torquey 258.
IF YOU DO have it (you still could have the T-176, which is a good tranny, but you'll have to check to be sure which it is) it is not simply swapped, you'd have to change the bellhousing and possibly have the driveshafts "adjusted" if the tranny length is different. You could swap just about any post-80 tranny in, if you were to go that route, since you would have to change the bellhousing anyway. You have a Dana 300 TC, that's why I say any post-80 tranny, because that will minimize any further changes you'd have to make in a swap.
But, before you swap anything or even think about it, check for sure which tranny it is. <img border="0" title="" alt="[Wink]" src="wink.gif" />
post #7 of 11 Old 05-21-2002, 07:16 AM
KG4PAM
Post
i had the same problem with my jeep. i have the sr-4 and 258. it was $415 of my parents money to fix. the reverse sliding gear and the reverse idler gear were chipped up. the mechanic said that he paid $130 for one gear and $150 for the other. i wouldnt have paid that much to fix it (expecially since 4wd hardware only charges about $55 and $63 for the same gears) except my mom answered the phone and told them to go ahead and fix it. i saved some money by removing the tranny myself, which took about 2 hours. again, i am talking about my sr-4. i dont know about any othere trannys. you can tell which one you have by several ways. the t-176(as far as i know) has a straight shifter stick, while the sr-4 has several curves. the top cover of the sr-4 has "13-32" cast into it, and possibly has the ford oval as wwell. the sr-4 has a cast ally case, while the t-176 is cast iron or steel?? as far as tranny swaps go, i read in 4wd hard. that a t-4 or t-5 will interchange with the sr-4. htey make a "world class" t-5 which i heard is good, but it costs like 1600 bucks. i hope that i have been of help to you, and good luck!! jairus
'81 CJ-7 Got it when I was 16!
'06 Hummer H3, boulder gray, Adventure Package(electric rear locker and 70:1 crawl ratio BONE STOCK)
'71 Kaiser-Jeep M35A2 Deuce and a Half cargo truck, with winch. <for sale>
KG4PAM is offline
post #8 of 11 Old 05-21-2002, 07:17 AM
chump
Post
hey if you don't want to bother with swithing things out i have a SR-4 in the shed i could sell cheap. depending on the shipping i'm sure i could cut you a better deal than the junk yard. let me know if your interested. jlott45701@earthlink.net
chump is offline
post #9 of 11 Old 05-21-2002, 09:52 PM Thread Starter
KNIFE
Post
THANKS GUYS ILL CHECK IT OUT TOMARROW I REMOVED THE BODY OF MY CJ TODAY.THE NEW FIBERGLASS BODY WILL BE HERE IN 2 WEEKS.GONNA START CLEANING UP THE FRAME AND PAINTING IT THEN UNDERCOATING.HEY CHUMP THANKS MAN ILL LOOK INTO SHIPPING SEND ME AN EMAIL WITH WHAT U WANT FOR THE TRANNY AND UR ADDRESS.MY JEEP WILL BE 99% AN ON ROAD RIDE GUYS.IT DOES HAVE 33 12X50S MAYBE TO MUCH TIRE FOR THE TRANNY.ILL POST WHAT I FIND ON THE TRANNY TOMARROW HOPE ITS NOT THE SR-4 LOL BRIMM660@AOL.COM
KNIFE is offline
post #10 of 11 Old 05-22-2002, 12:11 PM Thread Starter
KNIFE
Post
well its an sr-4.what to do what to do lol
KNIFE is offline
post #11 of 11 Old 05-22-2002, 01:10 PM
West
Post
If you have the body off your CJ now is a great time to put in any tranny. If you are serious enough about your jeep to do a tub you should upgrade tranny too
West is offline
RPMs after tranny swap. Which tranny? DT5150 Jeep CJ Forum 6 12-17-2008 05:24 AM
TF 727 Tranny ?s elks96 Jeep CJ Forum 1 07-04-2008 02:35 AM
CJ-7 1980 tranny help!! Tranny guys in here! Cherokeester Jeep CJ Forum 3 02-24-2005 02:44 PM
What tranny do I need? travr6 Jeep CJ Forum 23 04-19-2004 10:20 PM
will this tranny fit? J33P1N Jeep CJ Forum 1 02-11-2004 09:33 PM
