Tranny doesnt fit right - JeepForum.com
post #1 of 5 Old 08-27-2011, 06:34 PM Thread Starter
Eng1
I pulled the Tranny and t-case to replace seals. After getting them back in it seems to have shifted to the right side. The bolt for the t-case shifter is hitting the tunnel and the drive shaft seems to be off also. Also when looking down through the shifter cover it just does not look right. Should the rear output shaft be centerd between the frame rails or is it off set to one side. Any help would be greatly appreciated, I have been fighting this thing all week.
84 CJ-7 2.5, t-4 and 300.
Eng1 is offline
post #2 of 5 Old 08-27-2011, 07:11 PM
CJunk
It is offset.
Did everything bolt up? Maybe one of the engine or tranny mounts was bad and pushing things around messed them up a bit more.
CJunk is offline
post #3 of 5 Old 08-27-2011, 07:19 PM
MoC
When u pulled the tcase and tranny did you support under the engine or just let it hang?
MoC is offline
post #4 of 5 Old 08-29-2011, 08:23 AM Thread Starter
Eng1
Yes every thing will bolt back up with a little encouragement on the skid plate. And every thing was supported and nothing left to hang.
Eng1 is offline
post #5 of 5 Old 08-29-2011, 10:25 AM
alljagged24
Did u replace the tranny mount, my t5 has. A couple of different ways it can have the tranny mount installed on the tranny and skidplate which would cause this
fresh 258 .030 over comp cam ,clifford intake and header , holley 390 soa with procomp 2.5 in lift springs,2.5 in lift perches, d30 with detroit true trac, ford 8.8 performance limited slip 4.10 gears , 37 in iroks, custom bumpers and recovery points, super lined inside , no rust , fresh flat black paint, tested at trucksgonewild!!!
alljagged24 is offline
This doesnt look right? Jwfinley Jeep CJ Forum 11 08-20-2011 09:11 PM
Doesnt Want To Start teambean951 Jeep CJ Forum 3 08-28-2008 10:49 PM
something doesnt add up NHwheelin Jeep CJ Forum 49 05-03-2008 12:48 PM
something doesnt seem right, t150 jagerlager Jeep CJ Forum 4 08-25-2007 10:06 AM
so it doesnt exist, now what?? T-$$ Jeep CJ Forum 3 03-12-2006 06:03 PM
