Quantcast trailer wiring pigtail from cj harness how to? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > trailer wiring pigtail from cj harness how to?
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 09-02-2008, 12:38 PM   #1
COBRA5LADDICT
anyone have a write up? i need to wire up the cj for a flat 4 plug to tow a small trailer.
thanks!
COBRA5LADDICT is offline   Reply With Quote
Old 09-02-2008, 12:53 PM   #2
BioTex
OIIIIO
BioTex's Avatar
An easy way to do this is to purchase a 12v tester for a couple of buck at the Parts store. It will have a sharp point that you stick into the insulation of the wire, until it contacts the copper. The aligator clip will go to ground to complete the cicuit. This way you simply turn on a turn signal, and see which wire causes the light on the testor to blink. This will identify which wire is for that function. Then have someone hit the brakes, and see which wire causes the test light to illuminate etc... Hope this helps. If you need more detail, can do!
'85 CJ7, BDS 4" lift, 1" Body lift, 33x12.5, Shrockworks Sliders, 304 V8 with RV cam., T-176, D300, Dana 30, AMC 20.
1986 CJ10-A SD-33 Diesel/727/np208
1971 800B with 345/T-19
88' Comanche, 4.0L F.I., 5 spd.
BioTex is offline   Reply With Quote
Old 09-02-2008, 04:33 PM   #3
John Strenk
What was I thinking
1976 CJ5
I made my splices in the interior and ran them out the back door. That way the splice doesn't get attacked by spray thrown up by the tire.
John Strenk is offline   Reply With Quote
Old 09-02-2008, 06:24 PM   #4
Scrambler82
Scrambler82's Avatar
1982 CJ8
BioTex has the right approach except that the wires go Running Lights and Brake Turn.
Four wires are needed, Two Brake/Turn signals one for each side (large filament), one for the tail lights attached to both tail lights (small filament) and one for the ground( don't depend on the hitch to supply a good ground).
Scrambler82
Do it right the first time !
Scrambler82 is offline   Reply With Quote
Old 09-02-2008, 08:20 PM   #5
CrazyHorse6
1979 CJ7
[IMG][/IMG]
Hopefully this will help- you didn't mention what year or what type of CJ, so here is a wiring setup for a 79 CJ7. On mine I just tapped into the wiring harness as it runs along the tub next to the rear mount for the roll bar and have about 4 feet or so of slack to reach out to the trailer. This way its protected from the elements. The white wire carries the signal for your tail lights, the light green with TR is your left turn signal, the light green without TR is your right turn signal and the white with TR is for your backup lights.
On my trailer wiring harness, the brown was for the tail lights, the green was for the right turn, and the yellow was for the left turn and a white for ground. So, brown to white, green to light green w/out TR, yellow to light green with TR, and white to ground and you should be all set. Like BioTex said, have someone check you out first.
Good luck
CJ7, 258, Dana 20 T-case, Dana 30 & AMC 20, TFI Ignition upgrade, headers, MC 2100 carb, YJ tub mod w/Family Style roll bar...
Are you military or former military? Take a look at militaryjeepers.com!
CrazyHorse6 is offline   Reply With Quote
Old 09-02-2008, 09:11 PM   #6
mike06X
I think this is well covered here; but the flat-4 trailer harness standard color functions are..easiest way is with a 12v test light, probe, and those blue-squeeze scotchlock clips work out great..
white: ground
brown: tail
yellow: left turn / brake
green: right turn / brake
84 CJ7 - AMC360 & T727 | 35 BFG-KM2
mike06X is offline   Reply With Quote
Old 11-02-2009, 01:21 AM   #7
awful8484
I was really looking for a how-to to do this. I have an 85 CJ that needs a trailer harness too. Does anyone have any diagram on an 85 color code for the wiring loom running to the back? Much appreciated.
awful8484 is offline   Reply With Quote
Old 11-02-2009, 04:47 AM   #8
Cutlass327
1978 CJ5
Please, just unplug the 4-way to the taillight and operate the different lights while CAREFULLY probing the harness side of the connector. Piercing the insulation leaves the wire open to corrosion. Same as those dam scotch locks. I went to NAPA, got 2 complete 4-pin connectors that plugged into the harnes, and made a harness that fit in between the harness and the taillight. Do not jam the test light into the connector either, it spreads the connector contacts for a loose connection, just lightly touch the test light probe to the metal inside the connector. Even better is to add some dielectric grease in the cinnectors to help seal even better.
The taillights on mine have Red, Black, green (may be brown - I am rd/gr colorblind ), and white. Black is tail, red is stop/turn, white is ground, and the green is reverse. I used the 2 connectors, some 4-wire trailer harness wire, and a 4-pin trailer harness. Made 2 jumpers using the 4-conductor, one for each side. spliced into 4 wires of the jumper for the left side, and then into the turn signal wire of the right side. I made the length between the 2 jumpers long enough to go across to each side of the Jeep. In the middle I spliced in the trailer 4-pin. Solder and heat shrink all of the splices. Then all you need to do is disconnect each tail light, plug in your vehicle's harness to your new harness, then plug your harness into the tail lights. verify proper operation of the vehicle's lights, and also of the trailer's.
This will keep the vehicle's harness free from corrosion-causing hacking/piercing and it is also removable if you don't want the trailer's harness on the vehicle all of the time.
"Got four on the floor and four in the air on that one, didn't we?"
Nedmoore -> the best way to start your jeep without a key is to run a jumper wire between the red and black post on the battery and spin the fan behind the radiator at the same time. Good luck.
1978 CJ5 258/T150/D20, stock axles, 'glass tub and fenders, Bestop soft top, 31x10.5 BFG A/T, TDK galv'd frame - DD and weekend toy
http://www.jeepforum.com/forum/f8/ricks-build-thread-78-cj5-1223197/
Cutlass327 is offline   Reply With Quote
Old 11-03-2009, 07:48 AM   #9
BioTex
OIIIIO
BioTex's Avatar
It's in the FSM. There is a link to it here on the forum.
Old 11-22-2011, 11:36 AM   #10
red mistress
1983 CJ8
CJ taillight harness
This sums it all up!
I've been looking for way to add trailer wiring harness to CJ without splicing or scotch locks.
Guess U made your own.
Anyone else made plug-n-play or T connector trailer wiring harness for CJ ?
67 Gladiator 15K AMC327 PTO Ramsey D44, D60 69 Jeepster deluxe Convertible Power 82 CJ-8 75K Renegade all original 83 CJ-8 50K 401 MPFI ARB60's front & rear winch 38" 84 CJ-7 38K Garnet interior, Jeep SE 8274, 8" x 33" 87 J20 36K Jeep SE Hidden winch, boat rack, 35" 2006 LJ Rubicon 3K
red mistress is offline   Reply With Quote
Old 11-22-2011, 01:04 PM   #11
1986cj
I agree with John Strenk on this one. I had pulled a tail light off and there is a lot of wires in there. I got the drivers side to work and hooked up the pass side and the drivers side would not work right anymore. I finely got fed up (to put it nicely) and decided to hook it up before all the wires that are down there. On the back of the tub, Inside back where the hard top light plugs into the loom you will find the wires before they become a lot of wires. I drilled and put a grommet next to where the factory loom goes through and taped in my wires right there inside on the cab. Mine is a 86 but the Green wire is the right turn and the Green wire with a Black tracer was the left tail light. These two will also make your brake lights work. The White wire is the tail lights. I just ran a ground from the frame to the connector. Not needed but also in that loom is a White wire with Red tracer for the back up lights. Pink/Red is fuel sender and there is a orange and black wire that go to the dome light for the hard top on mine. I found this a LOT easer to do. Hope it helps.
1986cj is offline   Reply With Quote
Old 11-22-2011, 02:26 PM   #12
mopar408
Dysfunctional Member
mopar408's Avatar
1974 CJ5
As if a Jeep didn't have enough wiring problems already. If I had a dollar for every one of those things I've ever thrown away, I'd buy a TDK frame.
Soldered connections, heat-shrink tubing, dielectric grease and extra dedicated grounds.
If it's good TO you, it's gotta be good FOR you....
mopar408 is offline   Reply With Quote
Glock Forum
