Trail Master Lift - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Trail Master Lift
Build your Dream Jeep with Poison Spyder's Interactive GarIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!
Unread 10-31-2005, 02:32 PM   #1
blackyj
Trail Master Lift,good or bad
Does Anyone Have The Trailmaster 4" Lift On A Cj5?
I Bought A 77 Five With This Lift, And Fiberglass Tub It Seems To Ride Rough. I Have A Yj And It Rides Alot Softer. How Does It Flex Off Road(wheel Travel)?thanks
BLACK 95 YJ 2.5L 31X10.5 TRXUS M.T, HOME MADE FRONT BUMPER,HOME MADE REAR BUMPER WITH SWING AWAY TIRE CARREIR,OLYMPIC NERF BARS,HILIFT,KC LIGHTS,BEST TOP REPLACE-A-TOP WITH TINTED WINDOWS,lots of diamond plate, DYNOMAX MUFFLER, ELECTRIC COOLING FAN, JUNK YARD POWER STEERING,and a 2" body lift.2"add a leaf. 2002 grand cherokee, 77 cj5 32x11.5x15 m.t. 4"trailmaster, 2"shackles fiberglass everything,hardtop,bestop seats.
blackyj is offline   Reply With Quote
Unread 10-31-2005, 03:08 PM   #2
John C
What shocks do you have? I had a trailmaster ADD-A-Leaf on my old 74' Bronco with their brand of shocks. My god what a miserable ride. I changed the shocks out to Rancho's and ride quality improved greatly. Rancho's are known as a firm shock so to be softer than the trailmasters says a lot.
BlueJeep
BLUE JEEP CLUB MEMBER #156
84' Caribean Blue Laredo w/ black leather interior
Frame off restore 6 years ago
7 inch lift w/ 34" TRXUS MT
DANA 44 front Solid axle converted Model 20 rear
AMC 360 / T-400 / Model 300 transfer case
SOLD
but never forgotten
If I can't hunt it, fish it, f**k it, or wheel it, I might not be that intrested in it
John C is offline   Reply With Quote
Unread 10-31-2005, 03:40 PM   #3
blackyj
IT HAS Edelbrock Performer IAS shocks. http://pg.photos.yahoo.com/ph/hardta.../ph//my_photos
Unread 10-31-2005, 04:02 PM   #4
jeepskate
It's the springs combined with the shorter wheelbase.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
http://www.jeepskate.net
jeepskate is offline   Reply With Quote
Unread 11-01-2005, 03:56 PM   #5
blackyj
i am doing a frame up on the cj, so should i keep the trailmaster or go with a stock yj spring over. will the trailmaster flex as well as the yj springs? i need a new frame,so there wouldn't be a better time for the spring swap
Unread 11-01-2005, 09:41 PM   #6
jeepskate
I think you already know the answer to this if you think about it...
SOA versus a standard lift is a whole apples to oranges thing. Search and do your homework, SOA as well as SOA versus standard lift have been covered ad nauseum. Stock YJ packs will not last very long SOA. Not trying to sound like a jerk, but this really does get covered a lot and the info is easily found with a few searches both here, other forums, and the web in general. Once you've done your research, then ask questions if you need clarification on some of the finer points. Your intended use of the vehicle, budget concerns, etc will all play into your decision. Before you spend a single thin dime, you need to sit down and decide what you're expecting out of the final product...how you're going to use it, what you want it to look like, etc...then make a plan to get there. We'll help you on the finer details.
Unread 11-02-2005, 01:14 AM   #7
80cj
80cj's Avatar
1980 CJ5
I would imagine that your fiberglass tub is lighter than a regular steel one so the springs could be loaded less than they would be on a stock CJ-5 resulting in a stifer ride. I've also read somewhere that Trailmaster spring tend to be stiffer than some others. If you want to experiment, you might try removeing the bottom leaf from each spring pack.
80cj is offline   Reply With Quote
Unread 11-02-2005, 04:09 PM   #8
blackyj
thanks 80cj i will try that first. i think i found a frame for $400. all blasted & painted.
