Trail CJ build ?'s this is long but I like to get others ideas. - JeepForum.com
post #1 of 14 Old 09-15-2007, 12:58 AM Thread Starter
texascj77
I have been collecting CJ's for three years and still have the same decisions to make that I started with. I bought a 77 body on a 84 frame with worn 70something 304/t150/dana20, with a new pro comp 4" lift, and superior axle shafts rear, with wide track axles (2.73) gears on 33's and alum rims. The tub needed new floor boards front to rear, so I took it off and cut out the floorboards, now it sits that way.
I then bought a 86 sitting on a pair of 81 (narrow) axles with a trashed front ring and pinon, trashed frame, no engine, and a tub that needs steel replaced under the rollcage, and under the "JEEP" on the front rockers. So I took that body off of it and got about half the steel work done. I also bolted this 86 t176/D300 combo to my 304 with a new clutch in my 84 frame that has the lift and put in-frame headers and a flowmaster exhaust on the frame (still no body on it).
The 304 I have runs but it is tired, so I bought a 81 Cherokee Chief with a "built" 360/t176/208. I listened to the engine, it sounds good, has good oil psi and obviously has cam in it. It is still all bolted up and the Chief is complete minius driveshafts.
Now I bought a bone stock 83 cj7 with a worn out iron duke and near perfect everything else. I have been driving it everywhere, but the carb needs to be rebuild and it fogs mosquitos very well.
I also have a new centec harness and set of 1" body lift body mount kit, I also ended up with two decent sets of hard doors and a odd pickup cab that will fit a 7 with the factory roll cage still bolted in. Also have a couple of T18 ford trannys and 350/SM465 combo (the 350 is junk) but I would not mind using one of the granny 4 speeds, and buying a tcase adapter (would put jeep engine in front of the t18, or gm in front of the sm465).
Oh yea, got a 88 cherokee 4.0/auto that I rolled sitting in the warehouse too.
I want to end up with great trail rig (no lockers necessary type trails) and sell my leftovers to fund it. I dont mind buying another engine if the v8's I have are too much for a trail rig, and I prefer EFI. I will not separate the 83 frame and body. But will do whatever with the others as long as I have the leftovers to sell. I only want to keep one CJ.
I know I am rambling, thanks for looking. What ever suggestions you have will be considered. Is the procomp lift worth keeping for a trail rig on 33's? What is a good engine for trail rigs?
texascj77 is offline
post #2 of 14 Old 09-15-2007, 07:25 AM
CjinPA
CjinPA's Avatar
If you want EFI then use the 4.0 out of the cherokee, as long as the motor is in good shape. If you are running trails where you don't need lockers then you probably don't need a trans with a granny gear. I would use the T176 and D300 combo. Put the 4.0, T176, D300 in your 83 CJ. I would put the 1" body lift and procomp lift on it. That way when the procomp springs sag you will still have plenty of room for 33's with the 1" body lift. Sell the rest.
84 CJ7 Northstar V8
91 YJ Renegade.
I've been in this rut plenty long enough, I know what to expect. Weather my day is hell, or weather it goes well is kind of up to me I guess.
CjinPA is offline
post #3 of 14 Old 09-15-2007, 10:53 AM Thread Starter
texascj77
Good ideas.
All this 4.0 needs is new injectors. I have looked into installing it. What is the best way to put the cam sensor in the 4.0 swap? Hesco relocation kit or Novak kit, or others? How will it be with 33's on 3.55 axles with the t176?
post #4 of 14 Old 09-15-2007, 11:22 AM
supraman1990
supraman1990's Avatar
1980 CJ5
I believe it is Novak that will drill your current bellhousing for a factory cam sensor. That is the way I would do it if I were you. I personally wouldn't elect to use an 88 motor on account of the Renix injection, but If it were my only fuel injected option, I would do it. Also, if you don't want that CJ half-cab, sell it. If you have the bulkhead and everything for it that thing is worth some serious coin in good shape.
80 CJ5 in the process of a frame up resto
96% complete.
The little stuff will kill me.
On the back burner for college.
supraman1990 is offline
post #5 of 14 Old 09-15-2007, 11:46 AM Thread Starter
texascj77
If I am going to spend the coin for the 4.0 swap I will probably get a later engine, which is the easiest/best year?
I have the bulkhead and the little L pieces that fit around the rollcage. It has one little 1" crack at the bottom that I plan on getting fixed, still original white gelcoat and in good shape I plan on selling it. Any ideas on value?
post #6 of 14 Old 09-15-2007, 12:11 PM
supraman1990
1980 CJ5
OBD1 (91-95) engine and set-up would be easiest to do. In that setup their are 5 wires you have to splice, and that is it. That sounds like an OEM CJ8 half cab. If you get it fixed and it's in the shape you say, it could sell for I'd guess around $800 or higher. Do you have any pics of the cab?
96% complete.
post #7 of 14 Old 09-15-2007, 12:25 PM Thread Starter
texascj77
No cab pics.
I will get some. I don't think it is a factory cj8 cab because it will fit around a cj7 rollbar in the stock location, but I have only seen a few cj8 halftops and it has been a while.
post #8 of 14 Old 09-15-2007, 12:31 PM
supraman1990
1980 CJ5
A style or B style bar? If it was an A style bar, an OEM CJ8 top will fit a 7 with no problem.
96% complete.
post #9 of 14 Old 09-15-2007, 12:42 PM Thread Starter
texascj77
Whatever comes on a 86
This top is setting on my 86 CJ tub, with whatever rollbar came in it.
post #10 of 14 Old 09-15-2007, 08:43 PM
Oily
Everything is big in Texas.
Where do you live ?
Oily is offline
post #11 of 14 Old 09-15-2007, 08:46 PM
supraman1990
1980 CJ5
Does the front go onto the rear inner fender, or to the body?
96% complete.
post #12 of 14 Old 09-18-2007, 12:14 AM Thread Starter
texascj77
Near San Angelo
Where do you live ?
In the woods west of you.
post #13 of 14 Old 09-18-2007, 12:15 AM Thread Starter
texascj77
Not really following you.
Oh the rollbar, to the lower body.
post #14 of 14 Old 09-20-2007, 10:21 AM Thread Starter
texascj77
I got some pics of the hardtop.
How do I post them up? Pretty good at typing, that's where my computer skills start to suffer.
Thanks
5.3L swap and CJ-7 build! (long) lockedcj7 Jeep CJ Forum 56 02-27-2011 10:40 AM
Drivetrain Build Advice Trail and Second vehicle use, for now Woolys_CJ7 Jeep CJ Forum 1 10-20-2009 01:33 PM
SHARE IDEAS!! Need custom exhaust ideas for Chevy 350 Turbo! DWK213 Jeep CJ Forum 3 04-18-2009 09:57 PM
Frame off build up Ideas JFlanny11 Jeep CJ Forum 8 08-05-2008 01:49 PM
Howell TBI won't run long Any ideas?!? thedesertnomad Jeep CJ Forum 7 03-15-2007 10:27 AM
