traction bar for a SOA - JeepForum.com
post #1 of 13 Old 10-03-2005, 01:58 PM Thread Starter
Blthomas
Blthomas's Avatar
1979 CJ7
As I move slowly forward with my CJ, I have read and also been recommended by the local shop to have a traction bar on the rear end of the Heep. I did a search for traction bars and came up with alot of lift type stuff.
Anybody ever build their own? Gots pics and/or plans or ideas on what gauge metal to use, square versus round, to buyu one is looking at $300 plus shipping.
Besides, I'm learning to weld right now, be a great lesson from my friends if we could try building a traction bar.
Many thanks,
Blair
Blthomas is offline
post #2 of 13 Old 10-03-2005, 03:36 PM
jeepskate
Try searching on pirate4x4.com (don't post over there asking or you'll get flamed and told to search) and you should find plenty of info, plans, suggestions, etc.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #3 of 13 Old 10-04-2005, 09:18 AM
BlueTorch
check out my forum and gallery you will find pics. Feel free to post up on our forums. You will not get flamed.
We have a kit to build your own. Just call for details
Looks something like this
Blue Torch FabWorks, Inc.
205-521-7333 OR 866-RCK-CRWL
Check out our Facebook fan page!
[SIGPIC][/SIGPIC]
BlueTorch is offline
post #4 of 13 Old 10-04-2005, 11:50 AM Thread Starter
Blthomas
Blthomas's Avatar
1979 CJ7
Thanks for the heads up. I don't feel like I could fab one completely from scratch myself, but wouldn't mind a kit or at least some plans to follow. I registered at your site, did a quick search too. Is there a direct link that I'm not seeng to your traction bar somewhere? I'm looking for the direct info on cost and what it comes with.
My username is the same for your site.
thanks,
Blair
Blthomas is offline
post #5 of 13 Old 10-05-2005, 10:25 PM
mistertrustee
mistertrustee's Avatar
Sam's Offroad is where I bought mine from. They have two different versions.
mistertrustee is offline
post #6 of 13 Old 10-06-2005, 06:14 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I made one a couple years ago for my CJ when it was still SOA... used some old tie rod material that I had (1.25" OD x .315" wall DOM). It served me well and because it was slightly lower than my rear driveshaft, it made a good "ramp"... protecting my shaft somewhat from rock rash...
BESRK is offline
post #7 of 13 Old 10-06-2005, 06:39 AM
dawgates
1980 CJ7
Do you know anyone that has a old set of Chevelle traction bars? They would have to be a Lakewood style (ladder bar). That's similar to how BESRK and Blue Flame has there. Just turn it upside down it so it's not under the spring and dragging rocks. Just a thought!
80' CJ7, 360 Howell Injected, 3" single exhaust, NP435 4spd, Dana 300 AA clocking ring, Currie twin stick, Tera-Low 4 -1 kit, Dana 44 front, cut 10" wider to 63", 4.10 gears, ARB, Yukon axles and Super H/D u-joints, Currie Dana 44 rear, cut wider to 60 1/2", 4.10 gears, ARB 35 spline, Currie 35 spline axle shafts, 2 1/2" x 11" Ford drum brakes, CJ-SOA conversion, Tom Woods F & R drive shafts, Warn 9500i winch, 6 point cage, Homemade F&R bumpers and tire carrier, 1" body, Pro Comp supension Kit, 12.5x35x15 BFG's, 15x10 OMF beadlocks, Body armor, OBA.
dawgates is offline
post #8 of 13 Old 10-06-2005, 01:16 PM
Brandon11130
why do you need one for the rear with soa and not one for the front??
on most of the soa rigs ive seen they all had the rear traction bar and no front one
does the extra weight of the engine upfront give it more stability or what?
1959 JEEP CJ5
We do not ask for your poor or your hungry. We do not want your tired and sick. It is your corrupt we claim. It is your evil that will be saught by us. With every breath we shall hunt them down. Each day we will spill their blood ‘til it rains down from the skies.
Brandon11130 is offline
post #9 of 13 Old 10-06-2005, 01:23 PM
Brandon11130
sorry accidental post
1959 JEEP CJ5
post #10 of 13 Old 10-06-2005, 02:07 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
When in two wheel drive, all power is routed through the rear. This can cause excessive axle wrap on SOA setup's. A simple traction bar is a bracket that bolts to the top of the spring pad, with a vertical flange running parellel with the frame rail. Simply bolt a bar(fabed out of an old tie rod) through a bushing to a hole in the flange. A threaded stud welded on the other end(ala shock stud) goes through another ninety degree flange bolted to the frame rail. They look like a simpler version of BESERK's setup with the rear mount bolted to the U bolts. James Duff used to sell these for early Bronco applications(I'm sure he still does) for a reasonable price.
jeepdaddy2000 is offline
post #11 of 13 Old 10-06-2005, 02:31 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I've seen a few SOA rigs that would benefit from a front bar too... lots of axle wrap.
BESRK is offline
post #12 of 13 Old 10-06-2005, 02:36 PM
Brandon11130
so axle wrap is not so much of a problem of messing up your axle as it is your leafsprings. or will the perch bend also??
1959 JEEP CJ5
post #13 of 13 Old 10-06-2005, 03:03 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Won't mess up your perches but it's hell on your springs and can let the pinion tip up far enough to bind ujoints... usually causing an impressive ujoint/yoke failure.
BESRK is offline
Traction Bar Suggestions badady1 Jeep CJ Forum 8 10-14-2008 07:31 AM
Please help me fab a traction bar mdeis Jeep CJ Forum 6 07-18-2008 07:34 AM
Traction bar? tugboat Jeep CJ Forum 2 05-16-2006 01:16 PM
traction wilf Jeep CJ Forum 5 12-22-2004 02:23 PM
Traction Bar... BESRK Jeep CJ Forum 1 05-25-2004 11:13 AM
