traction - JeepForum.com
post #1 of 6 Old 12-21-2004, 06:51 PM Thread Starter
wilf
traction
I have stock axles and gears in my 80 cj5 jeep and the axles are stock dana 30 and amc 20 right? I put a 4 inch lift and 33x12.50x15 boggers on 15x8 wheels. it has the stock gm 151 (iron duke). i counted the ring and pinion and it has 3.54 gears with the rear having the limited slip or so the letter N stamped on it tells me. i am worried i will get stuck and only one of my front tires will spin and this will seriously make me mad. what does the front have in it limited slip or is it open? i would like to put one piece axles and lockers but that is in the future. thanks, blake.
wilf is offline
post #2 of 6 Old 12-21-2004, 07:12 PM
nickdz
nickdz's Avatar
My 80 CJ7 came with a 151 "Iron Duke" and it's gears are 3.54 with a limited slip AMC 20 rear axle (stamped with an "N"). My dana 30 front axle was an open diff. I haven't heard of any front axles comming with limited slip, but that doesn't mean that none did nor that yours doesn't currently have a limited slip. I would jack up the fron end and run some simple "spin the wheel" tests to make sure.
FYI...I installed a lock-right locker in my Dana 30 this past weekend. So far I am very pleased with the results. I have ordered an automatic locker for the rear as well and plan on installing it within a few weeks. Let me know if you have any questions.
1980 CJ7
- 151 "Iron Duke"/SR4 converted to Chevy 350/SM465
- Moser One-Piece Rear Axles
- Locked All Around
- Mastercraft Seats
- Durabak Interior and Exterior
- KargoMaster Cage
- Way too many minor repairs/upgrades to list (emphasis on "repairs")
nickdz is offline
post #3 of 6 Old 12-22-2004, 05:48 AM
CJ51973
CJ51973's Avatar
I would suggest that if you lock the front you lock the back. I had a limited slip in my rear 44. I upgraded to a lock right in the front. This made it much easier to "hop" up on stuff. But I had a near roll caused by (I like to blame my equipment rather than my own inabilities ) this combination. I was heading up a rock. Once the front came over the top it popped up a little loosing traction. The limited slip drove one tire (or the driving tire was in loose stuff) causing me to do a ballet move on one rear tire before it luckily slammed down. I thought I was scared until I looked at the guys watching me. They thought I was going turtle. The guy in front of me had a rear locker and a open front and had no issues. Softer springs and a rear locker and I can go up it like driving into my driveway.
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #4 of 6 Old 12-22-2004, 07:28 AM
jadams68
jadams68's Avatar
Limited slip is worthless in anything except mild muddy conditions.
Your front is open. 3.54 w/ 33's is cool.
Lock up the front...but if you do... upgrade your shafts and u-joints. They won't last long locked up.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #5 of 6 Old 12-22-2004, 01:42 PM
80cj
80cj's Avatar
1980 CJ5
Actually 3.54's with 33 and a four banger is a lousy combination. I would say at least 4.10's with the 4 banger and probably 4.56 or even 4.88 for really decent prformance.
Not all limited slips are the same. I used to have a TracLoc and it was worthless but since my sister-in-law drives my CJ-5 I decided to go to an Auburn instead of a locker. The Auburn seems to be quite tight and the improvement in traction very noticeable. I had an old CJ-6 with a Power Lok and performance was really great too. Depends on what your four wheeling requirements are. If you get your wheels off the ground a lot then I would say a locker is in order.
80cj is offline
post #6 of 6 Old 12-22-2004, 02:23 PM
jadams68
jadams68's Avatar
You're assuming he trails his vehicle to go offroading. With the ratios you're suggesting, his gas mileage will plummet as his 3 or 4 spd tranny sounds like a bee-hive going down the street at 3800 rpm
jadams68 is offline
Traction Bar Suggestions badady1 Jeep CJ Forum 8 10-14-2008 07:31 AM
Please help me fab a traction bar mdeis Jeep CJ Forum 6 07-18-2008 07:34 AM
Traction bar? tugboat Jeep CJ Forum 2 05-16-2006 01:16 PM
traction bar for a SOA Blthomas Jeep CJ Forum 12 10-06-2005 03:03 PM
Traction Bar... BESRK Jeep CJ Forum 1 05-25-2004 11:13 AM
