Towing a CJ7 with a Cherokee - Wiring - JeepForum.com
post #1 of 4 Old 05-29-2002, 05:32 PM Thread Starter
sswilcox
Question Towing a CJ7 with a Cherokee - Wiring
I am wanting to flat tow my CJ7 behind my Cherokee. I've already got the tow bar, hitch, etc. all set up. The only thing left is the wiring. Prepping the Cherokee with a 'trailer' harness is simple enough, but I'm curious if there is a way to connect directly into the CJ's existing electrical system and utilize it's tail lights and turn signals. Or do I have to act like a tow truck and buy those magnetic trailer lights?
It'd be great if there is just a simple way to plug one into the other.
Any help is appreciated.
sswilcox
sswilcox is offline
post #2 of 4 Old 05-29-2002, 05:57 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
Post
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by sswilcox:
<strong>I am wanting to flat tow my CJ7 behind my Cherokee. I've already got the tow bar, hitch, etc. all set up. The only thing left is the wiring. Prepping the Cherokee with a 'trailer' harness is simple enough, but I'm curious if there is a way to connect directly into the CJ's existing electrical system and utilize it's tail lights and turn signals. Or do I have to act like a tow truck and buy those magnetic trailer lights?
sswilcox</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">I am considering this also since I'm tired of using the magnetic lights. I checked the wiring harness and the rear loom unplugs close to the e-brake handle. I've heard there is a company that makes a plug and harness that inserts into the loom at this spot. I just haven't had time to research it yet. Hopefully someone here will know the answer and save me/us some work!
Steve
OldJeepguy is offline
post #3 of 4 Old 05-30-2002, 06:03 PM
MR.CJ-7
Post
I spliced into my wiring loom, but found out that the signal will backfeed through the turn signal switch, so you either need to get a diode or do what I did, which was put two toggle switches(one for left and one for right) in line between the turn signal switch in the column and the tail lights. That way when flat towing you can put the toggles in the "off" position and the signal won't backfeed. I have towed many miles this way and it works great. One plus is that when you hook up running lights you get all the running lights on your CJ. I put a seven-way truck end connector on my front winch plate and made a cord to go from my truck's 7-way to my CJ's 7-way. That way when not towing you don't have a cord on your CJ to worry about.
Just my $0.02
Former CJ'er
MR.CJ-7 is offline
post #4 of 4 Old 06-02-2002, 10:16 PM
Buff4lo
Cool
go buy three spools of three different colors of wire (white black and red?) Also get two replacement bulbs for your tailights (two filaments)and two generic bulb sockets. Glue the new bulb sockets into the tailight assy.'s and run wire from both new 'tailights' to the front of your Jeep. Put a 7-pin connector in your Jeep grill and wire up the lights. Then build a jumper wiring harness that attaches to your tow bar and connects your Jeeps together.
I did this on my CJ so I could flat tow it also. This is exactly the same concept as the magnetic light but it is clean and built in! Good luck.
Buff4lo
1977 CJ-7, D44 corp 20 detroits, D300, NP435, 304, 4" BDS, shackle reversal, 33X12.5 BFG MT's
Buff4lo is offline
SBC conversion wiring. What Jeep wiring to keep? DT5150 Jeep CJ Forum 14 01-04-2010 05:11 PM
Need wiring help on YJ Tach to CJ wiring danheit Jeep CJ Forum 4 12-31-2008 08:24 AM
Towing My Cj7 5STRINGINIT Jeep CJ Forum 8 12-06-2007 07:13 AM
Towing a CJ-7 jarm Jeep CJ Forum 4 11-25-2007 07:04 PM
Towing ? weedy Jeep CJ Forum 11 08-08-2004 08:22 PM
