towing a CJ - JeepForum.com
post #1 of 6 Old 06-26-2002, 07:22 AM Thread Starter
cjryder
Red face towing a CJ
Howdy all.
I heard that while towing a CJ, a dana 20 t-case won't lubricate adequately. Is this true? What do I do about it?
75 cj5 , 51 m38
"the wife asks 'why 2 jeeps?', I tell her that's all I could find so far"
cjryder is offline
post #2 of 6 Old 06-26-2002, 07:36 AM
MR.CJ-7
Post
I heard the same thing about my D300, but haven't had any problems. I suppose if you are worried about it you could put the warn full floater kit on the rear axle. When I tow mine I put the trans. in park, the T-case in N and go. Sometimes I put in the front hubs, with my locker it seems to center the wheels better after a corner but maybe its just in my head.
Just my $.02 worth
Former CJ'er
MR.CJ-7 is offline
post #3 of 6 Old 06-26-2002, 07:24 PM
cjdriver
cjdriver's Avatar
Post
Not sure about the 20 but the 300 for sure does not lubricate the rear output bearing when it is being towed. That TC uses the spinning of the mainshaft to fling and lubricate the bearing, so when it is in neutral being towed you are not getting any lubrication. As long as its short distances not a problem, but if you go any distance you need to do something about it.
One thing is to stop every 50 miles or so and drive it around to lube the bearing, but I think it is much easier to just remove the drive line. Thats what I always did. It takes 10 minutes if you are slow. 8 little bolts and you can just pop it out and go. This is the best way.
Jim Sykes
motorsports photography
cjdriver is offline
post #4 of 6 Old 06-27-2002, 10:47 AM Thread Starter
cjryder
Wink
Thanks for the feedback
Seeing as how I already bought the tow bar, this is all good news.
75 cj5 , 51 m38
cjryder is offline
post #5 of 6 Old 06-27-2002, 04:14 PM
MR.CJ-7
Post
owner's manual says on the 300 to stop every 300 miles or so and shift transmission into gear, leave T-case in neutral and run the engine for a few minutes to lube the bearing. My trips are always about 250 miles so I don't bother with stopping to lube it.
Former CJ'er
MR.CJ-7 is offline
post #6 of 6 Old 06-27-2002, 04:28 PM
cjdriver
cjdriver's Avatar
Post
300 sounds better, I knew it was something but could not remember exactly. I just took out the shaft and had nothing to worry about.
Jim Sykes
cjdriver is offline
cj5 towing dbd Jeep CJ Forum 6 08-24-2008 10:39 AM
CJ Towing or Tow Bar? dbd Jeep CJ Forum 18 08-10-2008 07:21 PM
Towing CJ bdub Jeep CJ Forum 6 06-01-2007 03:25 PM
Towing a CJ dawgates Jeep CJ Forum 5 06-15-2005 01:45 PM
Towing ? weedy Jeep CJ Forum 11 08-08-2004 07:22 PM
