Towing with 4 down - JeepForum.com
post #1 of 5 Old 03-03-2008, 05:48 AM Thread Starter
pnorris
1976 CJ7
Towing with 4 down
I know this question has been ask a 1000 times, believe me I seach the forum all weekend, but never got a warm and fussy answer in my case. I have a 1976 CJ7 w/I6,400 auto tranny w/ Quadra-Trac transfer case & full time 4WD. What is the proper way to tow it. Will it damage it to tow a long ways?
Last edited by pnorris; 03-03-2008 at 06:35 AM. Reason: It's Quadra trac, not Quadtra tech.
pnorris is offline
post #2 of 5 Old 03-03-2008, 06:44 AM
jayhawkclint
jayhawkclint's Avatar
1970 CJ5
I've flat towed several jeeps as far as 900+ miles. If you're going a long way, I've found for fuel economy purposes it's best to remove the rear driveshaft, unlock the front hubs, trans/t-case in neutral, and remove the windshield and top (store them in your tow rig).
My '70 CJ5 Build Thread:
jayhawkclint is offline
post #3 of 5 Old 03-03-2008, 06:44 AM
HackFabrication
HackFabrication's Avatar
1976 CJ5
Google.
I 'lifted' this from: http://www.autozone.com/az/cds/en_us...rInfoPages.htm Since it's from Auto Zone, take it for what it's worth.....
"If your Jeep must be towed, follow these guidelines:
A Jeep with a manual transmission can be towed with either all four wheels or either axle on the ground for any distance at a safe speed with both the transmission and transfer case in Neutral. (Edit: I believe there are oiling issues with the Dana 300 Tcase that should be addressed.)
To tow a Jeep with an automatic transmission and Quadra-Trac®, the driveshaft to the axle(s) remaining on the ground must be disconnected. Be sure to index mark the driveshafts and yoke flanges for alignment upon assembly. Also, the driveshafts must be tied securely up out of the way or removed completely while the vehicle is being towed.
A Jeep equipped with an automatic transmission and Quadra-Trac® with the optional low range reduction unit can be towed with all four wheels on the ground without disconnecting the driveshafts. Place the transmission shift lever in Park, the low range reduction unit shift lever in Neutral, and the emergency drive control knob in the Normal position. If the emergency drive system was engaged when the engine was shut down, it will have to be restarted and the emergency drive control knob turned to the Normal position to disengage the system since the control mechanism is vacuum operated.
WARNING
Never tow the Jeep with the emergency drive system engaged or the reduction unit in low range!
In all cases, unnecessary wear and tear can be avoided by disconnecting the driveshafts at the differentials and either tying them up out of the way or removing them altogether. Be sure to index mark the driveshafts and yoke flanges for proper alignment during assembly. If the Jeep is equipped with free running front hubs (manual transmission only), there is no need to remove the front driveshaft, simply disengage the hubs."
"In the end...It's all Hack."
HackFabrication is offline
post #4 of 5 Old 03-03-2008, 09:43 AM
bigjoe
1977 CJ7
2x's on what Hack posted. I "flat towed" my 77' with Quadra-Trac and the turbo 400 when I move to my new house. About 30 miles give or take. I just marked the yokes at the axle end, unbolted the shafts, tied them up out of the way under the Jeep and hooked up the tow bar. Hope this helps. Goodluck.
bigjoe is offline
post #5 of 5 Old 03-03-2008, 03:12 PM Thread Starter
pnorris
1976 CJ7
Thanks guys. I'm not sure if I will tow it with or without the drive shafts in place. I just hate to crawl under the jeep to do it every time, but still thanks for the input.
pnorris is offline
cj5 towing dbd Jeep CJ Forum 6 08-24-2008 10:39 AM
CJ Towing or Tow Bar? dbd Jeep CJ Forum 18 08-10-2008 07:21 PM
Towing CJ bdub Jeep CJ Forum 6 06-01-2007 03:25 PM
Towing a CJ dawgates Jeep CJ Forum 5 06-15-2005 01:45 PM
Towing ? weedy Jeep CJ Forum 11 08-08-2004 07:22 PM
