tough starting CJ - Page 2 - JeepForum.com
post #16 of 22 Old 06-14-2013, 10:49 AM
sanctified
Its hard to tell in my picture, and this is one I have saved from a while ago, but the filter should be level with the carb as well right? I am pretty sure that the filter sits a bit lower and I am not sure if I have enough length in the return hose to raise it but hose is easy enough to procure. What is a good way to secure the filter in the correct orientation and at the right level? How were they configured from the factory?
2013 JK (see info on left)
SOLD: 1983 CJ7
Utah Jeep Crew #178
sanctified is offline
post #17 of 22 Old 06-14-2013, 11:02 AM
waterdowg
I use to have hard starts. I still kind of do but much better since I replaced my battery. It use to take about a minute or so of cranking to start. Now I crank for about 10 sec. Stop turn the key and she fires right up. I noticed the engine spinning fast which means more fuel pressure.
waterdowg is offline
post #18 of 22 Old 06-14-2013, 11:08 AM
LumpyGrits
Replace your battery cables with custom 4/0 arc-welding cables and that cuts allot of loss.
Also, bolt your neg battery cable, that goes to the eng block directly to the mounting bolt on the starter.
LG
LumpyGrits is online now
post #19 of 22 Old 06-14-2013, 11:20 AM Thread Starter
tbart16
ahhhh that does make sense thanks for the clarification
'80 CJ 7 Laredo V-8
tbart16 is offline
post #20 of 22 Old 06-19-2013, 12:36 PM Thread Starter
tbart16
UPDATE:: Spun the fuel filter and amazingly enough the jeep starts much easier thanks Guys!!
'80 CJ 7 Laredo V-8
tbart16 is offline
post #21 of 22 Old 06-20-2013, 08:14 AM
ChaseKanter
Had the same issue with mine. Spun the fuel filter and now it fires up immediently. Wow, easiest fix ever. Thought I was going to go pretty deep in my wallet when I was going to eventually tackle that issue. Thanks!!!
ChaseKanter is offline
post #22 of 22 Old 06-20-2013, 08:21 AM Thread Starter
tbart16
I was figuring the same thing Chase. i actually got a great deal on my CJ because it was so hard to start.
'80 CJ 7 Laredo V-8
tbart16 is offline
