TOTW Fuel Injection - JeepForum.com
post #1 of 6 Old 08-19-2009, 11:37 AM Thread Starter
DUX4LIFE
1977 CJ7
TOTW Fuel Injection
How much hp gain would be realized by doing this swap? Or is it just a reliability issue? I have a 1985 258. I have the original aluminum intake with all of the smog stuff and an older steel intake without it. Which one would be better? Since all I have are the old 2 bbl and 1 bbl carters that need to be rebuilt I am thinking about going this route. Would a header be of any hp benefit with this scenario? Fuel milage increase? We don't have smog tests in our area so that isn't a conern. Thanks
DUX4LIFE is offline
post #2 of 6 Old 08-19-2009, 11:51 AM
CSP
How many threads are there on this subject already?
Throttle body injection won't yield more horsepower if your engine is tuned correctly as it sits. If it runs like crap you'll notice a difference.
Multi-port injection will yield horsepower gains, though they won't be huge.
In the end it comes down to drivability, reliability, and if those two items are worth it to you to either spend the money for a kit or invest the time it takes to figure out how to do it yourself and save some cash. It still isn't cheap to do it yourself, but you can save a significant amount and learn something in the process.
Lots of info has already been posted here and on the rest of the web.
CSP is offline
post #3 of 6 Old 08-19-2009, 01:18 PM Thread Starter
DUX4LIFE
1977 CJ7
Thanks, right now My engine is on a stand and the frame is painted. Adding things as they are being cleaned up and repaired. All I have is 2 old carbs and 2 diferent intakes. The carbs need to be rebuilt and I ain't a carb man. The write up on the injection was pretty stright forward and seems to be very affordable if I do it myself. Thats the way I am leaning towards. But when I started this project I wanted a simple uncomplicated jeep from the 70's. I may have to adapt though. FI seems to work pretty good when it is working.
DUX4LIFE is offline
post #4 of 6 Old 08-19-2009, 03:38 PM
Mike Romain
The kit for the 2BBl carb is only about $20.00 and is easy to put in.
You can also easily kill the computer and get a nice HP increase as well as over 20 mpg with all your stock stuff still.
Here is one writeup on killing the computer: http://www.jeepforum.com/forum/f8/ho...bypass-522262/
Mike
Mike Romain is offline
post #5 of 6 Old 08-19-2009, 07:58 PM Thread Starter
DUX4LIFE
1977 CJ7
Should I ditch the 1bbl and use the 2bbl that came with the 1985 engine or both and get another carb? Also should I ditch the steel or aluminum factory intake?
DUX4LIFE is offline
post #6 of 6 Old 08-19-2009, 08:42 PM
Mike Romain
The 2BBl and aluminum heated intake from the 85 work great.
Mike
TOTW Fuel Injection RockJeep Jeep CJ Forum 500 05-26-2015 03:55 PM
Fuel Sending Unit and Fuel Injection Question CJman77 Jeep CJ Forum 4 12-21-2009 05:01 PM
EFI, TPI, Fuel Injection CajunCountry Jeep CJ Forum 2 06-24-2009 04:32 PM
TOTW Fuel Delievery RockJeep Jeep CJ Forum 3 03-12-2004 10:38 PM
Fuel injection awachwhiteboy Jeep CJ Forum 1 04-25-2003 11:07 AM
