TOTW Fuel Injection - Page 6 - JeepForum.com
post #76 of 501 Old 02-09-2006, 11:32 AM
Blthomas
Blthomas's Avatar
1979 CJ7
Guys,
I think I got a good deal on some stuff.
90' Blazer, 4.3, for $100. Still runs, I get the whole truck for $100.
Figure maybe I can part it out for a few extra dollars.
Way better than the $200 I was looking at.
Been reading the writeup, looks good.
79' CJ7 - 4" lift, 33's
81' CJ8 bone stock
80' Chief "S" 6" lift, 33's
Blthomas is offline
post #77 of 501 Old 02-14-2006, 06:44 AM
jlynch
Will a tbi setup off a 89 camaro with a 350 work on a jeep 304?
jlynch is offline
post #78 of 501 Old 02-14-2006, 07:45 AM
CJ51973
CJ51973's Avatar
It should. The injectors in the TB may big too big (350 vs 304) but they can be swapped if need be.
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #79 of 501 Old 02-15-2006, 12:32 AM
Bill USN-1
If you are going to try and only run it on the stock chip then it may be a little rich.
The ECM will make adjustments to lean it out as you drive(within reason) but everytime you disconnect power it will have to relearn.... If you are going to tune it with a new chip for your motor or upgrade parts like headers and cam...then the 350 inj's are better for you.
FI Mod
Bill at Hamiltonfuelinjectiondotcom
Bill USN-1 is offline
post #80 of 501 Old 02-15-2006, 05:15 AM
CJ51973
CJ51973's Avatar
So the injectors are the same and the chip is the difference?
CJ51973 is offline
post #81 of 501 Old 02-15-2006, 05:46 AM
Bill USN-1
Nope,
you misunderstood.
Both are different.
The chip and injectors are different. If you grab a 305 ECM and the 350 TB, it will be rich. But if you plan to reprogram the chip for your motor anyway... than keep the larger inj's and tune it to those.
It's better to have the larger inj's that you can use later if you build up your 304(or go 360) than to find out later that the inj's you have are too small and you need to change.
You can tune a large inj down but a small inj will only feed a certain amount of HP.
You can turn the fuel pressure up so it shoots more fuel each time it fires but you can only go so high on the pressure with these inj's.
FI Mod
post #82 of 501 Old 02-15-2006, 07:10 AM
jlynch
I was going to try to reprogram the chip myself I have never done it before so it should be interesting. I have a stock 304 with headers so should I go with the 350 injectors and just reprogram the chip or should I get some 305 injectors?
jlynch is offline
post #83 of 501 Old 02-15-2006, 08:21 AM
Bill USN-1
I would use what is readily avail to you. Either will work in your case. If you plan future mods to the engine then i would lean towards the 350 inj's.
If your happy and just want to play with chips to see how they work, then go with the 305's with the 305 chip. Then it's close from the start. If you make mods later, you either change inj's or learn how to mod your regulator to boost the fuel pressure to the 305 inj's!!
FI Mod
post #84 of 501 Old 02-15-2006, 08:27 AM
jlynch
Can the stock jeep v8 dist. be modified to work with tbi or do I need to upgrade to hei?
jlynch is offline
post #85 of 501 Old 02-15-2006, 08:41 AM
CJ51973
CJ51973's Avatar
If it has a pickup and not points then it will work (see earlier posting). You'll have to use it with a GM 8 pin ignition module (or a 7 pin). The Duraspark system distributer will work (the one with the Motorcraft box).
CJ51973 is offline
post #86 of 501 Old 02-15-2006, 09:01 AM
jlynch
I must have missed the earlier posting sorry I'll read back thru. I do have the duraspark dist. so it can be modified for the ecm to control timing and spark?
jlynch is offline
post #87 of 501 Old 02-15-2006, 09:09 AM
CJ51973
CJ51973's Avatar
You need a distributer with an electronic pick up. To do timing control this distributer will need the mechanical & vacuum advance mechanisms locked so they will no longer adjust timing. The pickup wires hook to the GM ignition module. The coil and the ECU also hook to it. The distributer is timed at 0 degrees with D5 disconnected. Reconnect and the ECU does the rest.
CJ51973 is offline
post #88 of 501 Old 02-15-2006, 09:17 AM
jlynch
I have a gm hei dist out of a chevy 350. Any ideas on what would need to be done to get this to work in a 304?
I apologize I just read your answer from my HEI post. I will scrap the HEI idea and go with your advice. Thank you very much for all your info this is my first tbi project!!!!
jlynch is offline
post #89 of 501 Old 02-15-2006, 11:20 AM
CJ51973
CJ51973's Avatar
I am running on my understanding of what Bill USN-1 has told me, not personnal experience. I have only done this TBI/timing control on my 258. Bill, please correct anything I have mis-typed here.
CJ51973 is offline
post #90 of 501 Old 02-15-2006, 11:32 AM
Bill USN-1
Your doing fine, just keep in mind that it's not "electronic" distr, it's a distr with a magnetic pick up. That's why the HEI, large or small cap distr will work or the Ford DS distr.
The unilites, if they have the light...won't work even tho they are electronic.
Also there is a points replacement module made by Pertronix. It will not work either. Hall effect pick ups are not the same as magnetic pick ups and will not work.
The MSD Pro billets do use the same pick up as the DS distr so they will work.
Keep in mind that the mech advance must be locked out and you do not hook up a vacuum hose!!!
For another viable option you should really take a look at this thread!!!
Jamar performs the conversions for us and could probably do the same for you guys!!
May be worth looking into!!!
GM/IH distr merger!!!
FI Mod
Fuel Sending Unit and Fuel Injection Question CJman77 Jeep CJ Forum 4 12-21-2009 05:01 PM
TOTW Fuel Injection DUX4LIFE Jeep CJ Forum 5 08-19-2009 08:42 PM
Fuel Injection 304 Exposed Jeep CJ Forum 5 11-20-2008 06:40 PM
fuel injection on a 360 93YJNewf Jeep CJ Forum 3 11-09-2008 07:37 PM
TOTW Fuel Delievery RockJeep Jeep CJ Forum 3 03-12-2004 10:38 PM
