TOTW Fuel Injection - Page 33 - JeepForum.com
post #481 of 501 Old 12-23-2013, 09:56 PM
grantsjeep
1978 CJ5
Hey Guys,
I haven't read all 32 pages of this thread but I do have a question, I eventually want to go fuel injection on my 73 -5 but I only have a single barrel carter carb, do I need to have a two barrel intake to put the 4.3L fuel injection on my Jeep?
Thanks
Grant
grantsjeep is offline
post #482 of 501 Old 12-24-2013, 08:49 AM
CSP
Yes you do have to swap the intake. In the grand scheme of things, that's a minor task.
CSP is offline
post #483 of 501 Old 12-24-2013, 09:38 AM
grantsjeep
1978 CJ5
I'm more worried about finding the intake honestly
post #484 of 501 Old 12-24-2013, 11:43 AM
CSP
You can use any 2bbl manifold from '77 (I think that's the first yr of the 2bbl) all the way to the '90 Wranglers. Any '81 and up intake will also require the '81 and up exhaust manifold. AMC cars are also a source.
CSP is offline
post #485 of 501 Old 12-24-2013, 03:36 PM
mr_penguin
1983 CJ7
I have a 1983 2bbl intake and exhaust manifold. Pm me if you're interested.
Human subcultures are nested fractally. There is no bottom.
2006 KJ 65th Annv. 4x4 - Jeep Green
1983 CJ7 - Fresh AMC 360 w/ GM TBI, 31" Duratracs - Red
mr_penguin is offline
post #486 of 501 Old 01-02-2014, 09:31 AM
grantsjeep
1978 CJ5
Hey Guys,
I tried searching through this thread but didn't see this answered. Turns out I don't have a 258/4.2L, I have a 232/3.8L, with the 4.3L TBI swap still work as long as I get the 2BBL intake and exhaust right?
Thanks
Grant
post #487 of 501 Old 01-02-2014, 09:44 AM
mr_penguin
1983 CJ7
Yeah, it will still work. You may have to tune it a bit more to get optimal power due to the displacement difference, but it will definitely still work. Based on what I read on some other sites, the only difference between the two is a shorter stroke.
post #488 of 501 Old 01-02-2014, 09:47 AM
mr_penguin
1983 CJ7
On the same topic, I would highly recommend looking into the EBL Flash system for tuning. It eliminates the tricky chip swapping and EEPROM flashing. I used it on my 258 and was more than satisfied. I moved it to my new 360, and am thankful for the ease of flashing! Much tuning is in my future.
post #489 of 501 Old 03-29-2014, 01:49 PM
lcampbell89
Is there a more updated thread on how to do all of this? Or maybe a better parts list?
CSP I don't know if you will see this but you were talking about a pre cut harness where do you find that?
lcampbell89 is offline
post #490 of 501 Old 03-29-2014, 02:19 PM
CSP
Originally Posted by 1986cj View Post
CherryCj7 go here and read the sticky Fuel injection FAQ start here look for Dave Clifton's wire dragram and you have it all.. It is all there anything and everything you will need to know.
Injection Tech - Binder Planet Forums
An updated thread or better parts list? This thread either has all of the info needed or links to places that do like the other reply I quoted. You are going to have to do some research on your own just like everybody else does who does this via DIY. That binderplanet link has threads in it with info specifically listing what's needed.
I bought a pre terminated harness from Affordable Fuel Injection as part of their DIY setup to save some time. I don't know if they sell the harness alone.
CSP is offline
post #491 of 501 Old 02-15-2015, 11:59 AM
Kstein
I just posted a collection of parts for a 258 EFI conversion on the classifieds. It's not complete, but it's a good start. (Under Misc. Jeep Parts)
Kerry
TAMC85 CJ7
Still Original: Tub, Rollbar; Frame; 258 Block; T176; DANA300; Steering; DANA30; AMC20; Drive Shafts; Wheels; Tank; Altenator; Fan; Frt Bumper; Speedo; Heater Box; Spare Carrier; Seat risers
Replaced: Radiator; Valve Cover; Clutch linkage; Taillights; Frt Brake Calipers; Fuel, Tmp, and Oil Pressure Gauges; Exhaust line; Seat Belts; Paint
Mods: Mopar MPI(in progress); 4.0 Al Cylinder Head; OME YJ Suspension; MC Seats; Tub liner; 31" Tires
Kstein is offline
post #492 of 501 Old 05-25-2015, 07:55 PM
D_Dawson
1979 CJ5
I have a 79CJ5 with an AMC 360 in it. I live in the desert and the damn think keeps vapor locking. It gets warm and if I stop accelerating it dies. I have been told that the issue is most likely the ethanol in the gasoline nowadays. Same guy told me that putting an electronic fuel pump should solve my issue. That got me looking into fuel injecting it. I had it die on me doing a hill climb at altitude and was told that Fuel injection would solve that problem. I'm fairly new to this type of stuff, but I consider myself pretty handy with a wrench. I've done plenty or R&R stuff like fuel pumps, axles, valve cover gaskets, ect. So I don't think that this type of a project should be out of my abilities. (but I've been wrong before as my wife loves to point out).
Does anyone have any recommendations on how to go about doing these two things?
D_Dawson is offline
post #493 of 501 Old 05-26-2015, 03:20 AM
AZ_Chip
1981 FSJ Cherokee
Dive down the rabbit hole below
http://www.jeepforum.com/forum/f8/junkyard-tbi-2933529/
1981 Jeep Cherokee Chief S
AZ_Chip is offline
post #494 of 501 Old 05-26-2015, 03:25 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
If you aren't a fan of junkyards and used parts, there are several companies that make FI kits for your engine. Howell, Affordable, and MSD to name a few.
Matt
Matt1981CJ7 is offline
post #495 of 501 Old 05-26-2015, 03:27 AM
AZ_Chip
1981 FSJ Cherokee
Aww Matt, Used parts need love to.
If going new, I vote for Hamilton Fuel Injection. Bill is the best, he helps all.
AZ_Chip is offline
Fuel Sending Unit and Fuel Injection Question CJman77 Jeep CJ Forum 4 12-21-2009 06:01 PM
TOTW Fuel Injection DUX4LIFE Jeep CJ Forum 5 08-19-2009 09:42 PM
Fuel Injection 304 Exposed Jeep CJ Forum 5 11-20-2008 07:40 PM
fuel injection on a 360 93YJNewf Jeep CJ Forum 3 11-09-2008 08:37 PM
TOTW Fuel Delievery RockJeep Jeep CJ Forum 3 03-12-2004 11:38 PM
