TOTW Fuel Injection - Page 11 - JeepForum.com
post #151 of 501 Old 03-08-2006, 12:19 AM
Bill USN-1
There are several ways to wire them.
IIRC there are letters on the plug or relay.
Mine also had a little diagram on them.
I can take some pics of a couple I have at home, after work today.
FI Mod
Bill at Hamiltonfuelinjectiondotcom
Bill USN-1 is offline
post #152 of 501 Old 03-08-2006, 09:23 AM
jlynch
Mine has letters on the relay and the plug they are a-f. It also has a diagram on top of the relay but its like reading chinese for me.
92 Jeep wrangler/ Chevy 350/ sm465/ 205/ Dana 60/ Dana 70/ 4.56 gears/ detroit locker/
jlynch is offline
post #153 of 501 Old 03-08-2006, 11:06 AM
Bill USN-1
To start with go to this link and get the diagrams.
You want to get sheet 2 and 3.
At the bottom of sheet 2 is the FP relay circuit for the S/T M series of trucks.
I will use it for the explaination.
diagrams
Here's the diagram...
Note:
Pin A comes from the ECM pin A1 and is used to apply 12V to the relay to turn it on.
Pin C is the ground wire. Can be connected to one of the black/wht wires.
Pin D is your 12V from a fuse. This is normally tied to the org wires B1 and C16. It is the same that provides the bat 12V to the ECM.
Pin B is the output of the relay going to the Fuel Pump or any other load you have connected to it.
This also ties to pin B2 of the ECM to tell it when the FP is actually running.
Now the pin letters may not be exactly the same as this diagram. That's not important. It you follow the diagram here and the description and just match it up to the diagram on your relay!!!
FI Mod
post #154 of 501 Old 03-12-2006, 06:52 PM
jadams68
jadams68's Avatar
Writeup has been updated:
http://www.bustedjeep.com/projects/junkyardtbi.asp
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #155 of 501 Old 03-14-2006, 12:55 PM
rjcj-8
Kevin ,
since it looks like you are running OBA off your motor have you though of programing your chip to use the AC on sense to increase your RPMs while the OBA is on to increase air out put?
rjcj-8 is offline
post #156 of 501 Old 03-16-2006, 12:32 PM
ChiliPepperTJ
ChiliPepperTJ's Avatar
Well I think it has it programmed into it already, but I'm not sure. I have the ac wire labeled, but I have not hooked that up yet. If the vechicle the ecm came from had ac, wouldn't it be programmed? I have a hand throttle on the cj too so if its not programmed into it I don' think I'm gonna get a chip burned yet unless I need to. I just bought a VSS from howell for $100 shipped. I figured I got it this far might as well do it right and get a vss. I'll be smog legal then, but I don't go over 5000 miles a year so I'm exempt anyway. I still have to bump up my fuel pressure on the tbi too so as soon as I do that and get the vss in I'm gonna log some more data. I gotta stop spending money on this thing :-D.
Kevin
84 CJ-7 Renegade- 258,GM TBI w/ ESC, HEI, T-5, D300, D30, AMC 20 w/ trac loc and superior shafts, 2.5" BDS lift, 1" daystar BL, MORE shackles, Tie rod flip, 33" Swamper SSR's, Full cage, OBA, A to Z rocker guards, A to Z rear cage, Warn 9.5ti, Taurus fan, Herc'd tub, LED tail lights, Hand throttle, Hella Fogs, Hella headlight conversion, more to come...
02 WJ Limited, 4.7 H.O., RB1 Nav, DD and toddler hauler
Checkout my Junkyard TBI writeup:
ChiliPepperTJ is offline
post #157 of 501 Old 03-16-2006, 12:37 PM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
How do you know/Why do you have to do this?
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
post #158 of 501 Old 03-16-2006, 12:42 PM
ChiliPepperTJ
I made the cable to hook it up to my laptop and downloaded the program that reads the ecm. Its called winaldl. I sent the file I logged to bill-usn1 and he read it and told me I am lean at idle. I have to adjust the fuel pressure regulator on the tbi injector pod. Its easy too do I've just been busy and didnt do it yet.
Kevin
post #159 of 501 Old 03-16-2006, 02:19 PM
rjcj-8
what is programed into the stock chip is a short increase to compensate for the compressor kicking in.
I'm doing the electronic version of the hand throttle.
My chip is programmed to increase idle to about 1300rpm when there is +12 on the ac wire. I had connected mine to the compressor and to a switch so i can either have the rpm increase when the oba kicks in or i can hit a switch and it will kick the rpms up to 1300.
rjcj-8 is offline
post #160 of 501 Old 03-16-2006, 02:21 PM
ChiliPepperTJ
rjcj8 thats a cool idea. Do you have the ability to burn your own chips?
Kevin
post #161 of 501 Old 03-17-2006, 06:49 AM
rjcj-8
no, not yet. I'm thinking about it but I'm going to wait till i can get some data logged and see how she is running one i get the motor broke in, still have less than 500 miles on her so far.
I got my chip from AFI and they had programed that in for me. So far it seams to be on the money. I'm running computer controlled timing with out the knock or vss.
Have not had it ping running low octane fuel.
rjcj-8 is offline
post #162 of 501 Old 03-17-2006, 07:56 AM
jlynch
How much did AFI charge you for the chip?
jlynch is offline
post #163 of 501 Old 03-17-2006, 11:04 AM
rjcj-8
It was $95 plus shipping of a few dollars.
They have real good service and I recommend them if you can not burn your own.
Or want a chip that is real close to begin with.
rjcj-8 is offline
post #164 of 501 Old 03-19-2006, 01:15 PM
18to80DDC
Built Not Bought
18to80DDC's Avatar
I've been searching the CJ forums but can't seem to find anything.
Is there a AMC 360 TBI option that I could just pull off another motor and put on mine, or am I left with only the 350's that need modding?
Also, did the '73 and '82 six's come stock with an EGR? I got both mine after the six was gone so I have no idea if I need one on the 360's
2001 4.0L Wrangler Sport - 3.5" lift on 33's
1973 CJ5 360 - 4" lift on 35's
1982 CJ7 360 - 2" lift on 32's
1971 Series III E-type Jaguar V12 - no lift...
18to80DDC is offline
post #165 of 501 Old 03-20-2006, 06:51 AM
jlynch
I think the 350 is as close as your going to get for your 360. I was told it will run fine using the stock 350 chip but reprogramming the chip is recommended for better performance.
jlynch is offline
Fuel Sending Unit and Fuel Injection Question CJman77 Jeep CJ Forum 4 12-21-2009 05:01 PM
TOTW Fuel Injection DUX4LIFE Jeep CJ Forum 5 08-19-2009 08:42 PM
Fuel Injection 304 Exposed Jeep CJ Forum 5 11-20-2008 06:40 PM
fuel injection on a 360 93YJNewf Jeep CJ Forum 3 11-09-2008 07:37 PM
TOTW Fuel Delievery RockJeep Jeep CJ Forum 3 03-12-2004 10:38 PM
