torx bolts on rear diff - JeepForum.com
post #1 of 9 Old 05-17-2002, 07:06 PM Thread Starter
dpoliver
Angry torx bolts on rear diff
They strip so easily..
once the damage is done how am I supposed to get them off...any tips?
don't want to try any of the others till I get some ideas...
once they're off though...
I'll be replacing them with something else...
any little tips would be great..
dpo
86 cj7 4.2l i6,torqueflite 904 at,
GM hei ignition, weber,
31 in a/t tires, so far...
dpoliver is offline
post #2 of 9 Old 05-17-2002, 08:18 PM
mozz
mozz's Avatar
Post
I had to use either needle nose vise grips or a chisel and hammer.
'78 CJ7
360 cid W/390 heads
edelbrock intake W/matched performer plus cam,springs and timing chain
Hedman Fenderwell headers
4WD Fiberglass Body
4" lift W/ 35" BF Goodrich AT
Pioneer CD player W/ Pioneer 200 watt amp 10 in. sub speaker box Shoved behind rear seat for now (Till I can make a permanent box)
mozz is offline
post #3 of 9 Old 05-20-2002, 11:12 AM
Dustin Maschino
Post
goto an auto parts store or somewhere that sells tools and get a set of left handed, or backwards drill bits and drill it out with the drill in reverse and the drill bit should snag and screw it out...thats how we take care of stripped out bolts at home...
Dustin Maschino is offline
post #4 of 9 Old 05-20-2002, 12:57 PM
4wheeler4CJ
4wheeler4CJ's Avatar
Arrow
I have used vise-grips very successfully on torx bolts.
4wheeler4CJ is offline
post #5 of 9 Old 05-20-2002, 09:41 PM
MR.CJ-7
Post
Another vote for the vise grips.
Former CJ'er
MR.CJ-7 is offline
post #6 of 9 Old 05-21-2002, 06:19 AM
Bulletproofcj7
Post
And another vote for the vise grips!
I think craftsman makes a "screw out" for buggered screws, cant imagine they work all that well for that size bolt though.
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
post #7 of 9 Old 05-21-2002, 08:02 AM
4wheeler4CJ
Arrow
Torx bolts tend to have a signifigant-sized head on them, with sufficient "flat-area" to be able to grab them well with vises. <img border="0" title="" alt="[Wink]" src="wink.gif" />
post #8 of 9 Old 05-21-2002, 09:13 AM Thread Starter
dpoliver
Post
did one better...
used my wife little dremel tool with a cutting blade on it...
cut two sides so i could fit a 1/2 wrench on it...
worked like a charm...
took some doing ..space is limited..
replaced them with some stainless bolts for the next time..
dpo
dpoliver is offline
post #9 of 9 Old 05-21-2002, 04:54 PM
Boggy Bottom
Post
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by dpoliver:
<strong>replaced them with some stainless bolts for the next time..
dpo</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">Be careful about using stainless steel. I just want to caution everyone that just because it's stainless, doesn't mean it's the correct fastener for the job.
Stainless is good stuff, but it's "gummy." It can shear easily if you get the wrong kind, and it can really mess up threads if used in softer materials like aluminum. What I mean by that it that it has a certain softness and malleability to it that doesn't always lend itself to the application. Stainless is pretty, but be aware that because of the high content of chromium and vanadium in it, it doesn't behave under stress like good ol' carbon steel.
They do make high-strength, heat-treated stainless bolts. Stainless it fine, but if you take out a Grade-8 bolt, be sure to replace it with a grade-8. Your Jeep will live longer that way.
Sorry, LOL I don't mean to preach. I just been a mechanic my whole life (industrial & aircraft). Oh yes, and I recommend the vise-grips too. Get a nice new pair, the serrations on the jaws will be nice and sharp!
Ol' Boggy Bottom
'83 & '84CJs, '51, '53, and '57 Willys Pickups
Boggy Bottom is offline
snapped brake line and rear diff bolts stripped maxamillion Jeep CJ Forum 8 03-26-2015 11:00 AM
Help! i have stripped out one of my bolts on my Rear Diff, how do get it out? Smitm16 Jeep CJ Forum 28 05-23-2011 09:20 AM
Torx Bolts jkaras2000 Jeep CJ Forum 2 08-23-2009 02:40 PM
torx bolts Sedorbrian Jeep CJ Forum 5 03-23-2009 08:25 PM
Torx Bolts........... custom-cruiser Jeep CJ Forum 11 11-14-2004 03:35 PM
