Torx Bolts - JeepForum.com
post #1 of 21 Old 07-11-2012, 06:31 AM Thread Starter
nichboy
Torx Bolts
I did a search and was over whelmed. Can someone recommend a good set of torx wrenches for dismantling my jeep and do you recommend using torx bolts on the rebuild or something else. Thanks
nichboy is offline
post #2 of 21 Old 07-11-2012, 06:48 AM
jponrshsbnd73
Harbor freight has a great set , t-15 up to t-60 for 10$
"I don't start worryin until it stops leakin!"
jponrshsbnd73 is offline
post #3 of 21 Old 07-11-2012, 06:56 AM
brownbagg
1930 MK Compass
yes harbor freight, you are going to break them, no matter what brand, and no, no torx on rebuild
brownbagg is offline
post #4 of 21 Old 07-11-2012, 07:10 AM
Scott21
Use craftsman or snap on. They break. Both companies will replace them.
Scott21 is offline
post #5 of 21 Old 07-11-2012, 07:15 AM
bentshackle
1983 CJ7
I would suggest a selection of nuts from your local hardware store and a mig welder to stick said nuts to the top of your Torx bolts. Its the only consistent way I've found to get the things out.
Also if you decide to use those god forsaken things in a rebuild I will hire a monkey to screech and fling his feces at you.
bentshackle is offline
post #6 of 21 Old 07-11-2012, 07:18 AM
jponrshsbnd73
^^^^lmao
post #7 of 21 Old 07-11-2012, 07:23 AM
andygio71
Great, now my ribs hurt
andygio71 is offline
post #8 of 21 Old 07-11-2012, 08:08 AM Thread Starter
nichboy
My My guess i didn't realize the hatered towards torx bolts,(i may after i start removing them) what do you recommend for replacements. Seems like i saw a thread that listed the different size bolts needed for a rebuild.
nichboy is offline
post #9 of 21 Old 07-11-2012, 08:14 AM
82custjeep
1982 CJ5
use stainless hex screws and bolts on a rebuild. A little more money but well worth the investment
82custjeep is offline
post #10 of 21 Old 07-11-2012, 08:44 AM
mooncruiser
Just stripped out a couple of these darn bolts(windshield hinges)-had to use an extractor. Bout the straight Hanson fluted type (like an easy out), drilled out the center of the bolt and backed them out-I sure as heck will not be using torx bolts when I put it back together after painting.
mooncruiser is offline
post #11 of 21 Old 07-11-2012, 09:29 AM
WindKnot
1977 CJ7
Torx was invented for mass production assembly. You're not doing that so skip them.
I'd be wary over the idea of stainless steel fasteners for everything. I'd probably agree with body and some frame fastening, but be careful in engine, exhaust and suspension assembly.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #12 of 21 Old 07-11-2012, 10:05 AM
82custjeep
1982 CJ5
I agree. Use stainless for windshield and some body accessory mounting. Stick with grade 5 and 8 for suspension and engine
post #13 of 21 Old 07-11-2012, 10:14 AM
Always2L8
1982 CJ8
And don't forget http://www.permatex.com/products/aut...ubricant_a.htm when re-installing.
Always2L8 is offline
post #14 of 21 Old 07-11-2012, 01:55 PM
248107
Guest
1983 CJ7
Allen bolts also in tight places like exhaust and intake manifold,maybe valve cover
248107 is offline
post #15 of 21 Old 07-11-2012, 02:00 PM
Crazyray2929
1981 CJ7
I just had to drill 2 out of my windshield frame...
Going back on with hex heads...
Crazyray2929 is offline
Torx Bolts jkaras2000 Jeep CJ Forum 2 08-23-2009 01:40 PM
*@$*ing Torx Bolts rkbell Jeep CJ Forum 17 03-31-2009 11:55 AM
torx bolts Sedorbrian Jeep CJ Forum 5 03-23-2009 07:25 PM
#@%$&##(&^% Torx Bolts!!!!!! KSToyz Jeep CJ Forum 37 11-15-2007 06:12 PM
Torx Bolts........... custom-cruiser Jeep CJ Forum 11 11-14-2004 02:35 PM
