Torn Between tire sizes. Help! - Page 2 - JeepForum.com
post #16 of 20 Old 02-18-2013, 08:38 AM
CALOcruiser
CALOcruiser's Avatar
1978 CJ7
Originally Posted by Jamesromeos View Post
Also, in the pictures she is running on 32x11.50's now. Can you fit a 12.50 wide tire on those rims?
Thanks in advance for your help
Also should mention you'll need wheel spacers for the 12.50's if you have a narrow track axle (which you probably have wide-track in '83). Mine were rubbing on the leaf springs without spacers, and I have a high offset 15x10 rim. check the offset of your rim at the very least.
CALOcruiser is offline
post #17 of 20 Old 02-18-2013, 08:42 AM Thread Starter
Jamesromeos
1979 CJ5
Im going to roll under it in a bit to see if I can see the markings on the case. It is 13 Degrees here....LOL
Jamesromeos is offline
post #18 of 20 Old 02-18-2013, 02:24 PM Thread Starter
Jamesromeos
1979 CJ5
Cant find any markings anywhere....I checked and cleaned the entire area...anyone have a pic of where they found the #?
post #19 of 20 Old 02-18-2013, 02:30 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
If you can't find the code, jack the rear end up, put a chalk mark on one of the tires, turn the tire 360 degrees and count how many times the driveshaft turns.
That will get you close.
Matt
Matt1981CJ7 is offline
post #20 of 20 Old 02-18-2013, 02:34 PM
CALOcruiser
1978 CJ7
mine was on the indicated area. sorry, can't get to my jeep to take a pic. you have to look hard. It may be worn smooth.
