Top radiator hoses sucks itself together under throttle - Page 2 - JeepForum.com
post #16 of 20 Old 09-18-2011, 12:04 PM Thread Starter
IrishCJ6
1975 CJ6
Thanks guys for the responses, found the old top hose learking in the garage (with spring) and put it on and it works no more collapsed hose.
But I still have a standard bottom hose (no spring) can anyone give me the right part numbers of the top and bottom hoses (with springs) so I can get replacements.
As with being in Ireland the easiset distributor I've found is Rockauto so there parts numbers would be helpful.
IrishCJ6 is offline
post #17 of 20 Old 09-18-2011, 12:29 PM
davbytrace
1979 CJ7
Good info Jeephammer.
The voids created by the cavitation of an impeller are created by the low pressure on the backside of the impeller blade. The low pressure forces water to convert automatically from liquid to a gas, but it does not introduce air into the system because the pressure in the system and the (relatively) low temperature. It creates steam.
Since the water is at a near boiling point it only takes a little bit of negative pressure for the vapor pressure in the water molecules to exceed the system pressure. That negative pressure is created on the back side of the impeller. This creates little steam voids.
The steam voids collapse immediately on the other side of the impeller because the steam void is not created by heating (like a pot on a stove), it is created by negative pressure.
davbytrace is offline
post #18 of 20 Old 09-18-2011, 03:25 PM
bentring
1976 CJ5
I needed a new top radiator hose and two different places listed it as one that wasn't going to fit so I just decided my setup wasn't stock and bought a flex hose. Problem solved.
bentring is offline
post #19 of 20 Old 09-18-2011, 04:06 PM
80cj
80cj's Avatar
1980 CJ5
Could it be possible that you have a water pump designed for a serpentine setup and it's turning the wrong way? Nah, impossible! Just a far fetched thought.
80cj is offline
post #20 of 20 Old 09-18-2011, 07:18 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Not with the V8. They didn't have viper belts.
John Strenk is online now
Ford Radiator Hoses.... Exposed Jeep CJ Forum 8 04-08-2013 04:37 PM
ford 302 swap radiator hoses petey156 Jeep CJ Forum 6 09-03-2010 12:34 PM
radiator hoses kjmills Jeep CJ Forum 1 07-07-2008 08:10 AM
Blocking off radiator hoses for heater in cab 00xjnewb Jeep CJ Forum 4 12-22-2007 03:00 PM
Radiator hoses brypten Jeep CJ Forum 0 08-07-2006 09:42 AM
