TKFireman's build thread - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > TKFireman's build thread
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6
Unread 01-25-2011, 06:55 PM   #76
benullman
1981 CJ7
Originally Posted by TKFireman View Post
Thanks Ben, still got a long ways to go.
I plan on all bolt heads, brackets and maybe a few other parts to be black, we'll see how that goes.
thats what I did
you can kind of see it in that picture.
Ben
[QUOTE=Gregg79CJ7304;11634021]Great minds think alike, but so do serial killers......Thanks.[/QUOTE]
benullman is offline   Reply With Quote Quick reply to this message
Unread 01-25-2011, 08:42 PM   #77
Magical_Merlin
1976 CJ5
Here is my 401. Putting it in as we speak. It is Pontiac Blue.
Magical_Merlin is offline   Reply With Quote Quick reply to this message
Unread 01-25-2011, 09:01 PM   #78
swatson454
1983 CJ7
Not really related to the thread but Pontiac Blue appears to more closely match the Ice Blue Metallic of my old bomb better than AMC Blue. Hopefully it's not taboo to do such a thing.
Thanks for the pic and idea.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now   Reply With Quote Quick reply to this message
Unread 01-25-2011, 10:00 PM   #79
82JeepCJ7
1982 CJ7
that is Duplicolor Ford dark blue, got the idea of coloring the "401" from your pictures I've seen in the past, first picture looks a lighter in color because of the light.
That is the exact same paint I used.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline   Reply With Quote Quick reply to this message
Unread 01-25-2011, 10:37 PM   #80
swatson454
1983 CJ7
I just went back and checked the previous page and I stand erected; the Ford blue looks pretty damn sweet and won't upset the Jeep Gods the way a Pontiac color might. Looks good dude
Shawn
Unread 01-26-2011, 06:28 AM   #81
fuzz401
1978 CJ7
Looking good just take your time putting it back together
alignment dowels for the heads if they fit the heads and block I would just reuse them or try here Performance American Style (http://www.performanceamstyle.com).
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
http://img2.photobucket.com/albums/v...slideshow=true
http://photobucket.com/albums/v31/fu...slideshow=true
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline   Reply With Quote Quick reply to this message
Unread 01-26-2011, 08:39 AM   #82
TKFireman
1980 CJ7
One of my dowels is bent, 1/2" bolt won't fit through it, may be able to straighten it. Thanks for the link, if there cheap, I'll just replace
I went with the ford dark blue because my jeep is painted 2010 ford dark blue metallic, thought the colors might line up well, jeep is a good bit darker though
Shawn, can you plug the stats in your desk top dyno now that I have the cam specs and see what you get? How much will the deck machined .015" and the heads machined .010" affect my compression ratio?
"If your gonna be dumb, you gotta be tough"
Build Thread
TKFireman is offline   Reply With Quote Quick reply to this message
Unread 01-26-2011, 08:48 AM   #83
fuzz401
1978 CJ7
if you are looking for CR you need some of these
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
Unread 01-26-2011, 11:25 AM   #84
TKFireman
1980 CJ7
I'm not really looking for more CR, didn't splurge for the 9.5 pistons, was just wondering if decking and resurfacing would change the stock 8.25 CR to say maybe 8.5 or not? Is removing that small amount gonna make a difference?
Build Thread
Unread 01-26-2011, 07:50 PM   #85
mopar408
1974 CJ5
as sweet as your setup is, don't even dream of putting it back w/o the Bulltear timing cover/oil pump setup w/ the "steel plate" on the bottom. Peace of mind alone is worth it and it'd be a damn shame to have to go back into it after all this work. The old man does good work and use his pump and checkvalve parts.
Take your time and bench-build it w/ plastiguage and EP moly.
If it's good TO you, it's gotta be good FOR you....
mopar408 is offline   Reply With Quote Quick reply to this message
Unread 01-26-2011, 07:58 PM   #86
frankenjeep
1994 ZJ
Don't know if any one has mention it and not sure how far you are but there's a oil mod for the oil system that helps evenly distributes the oil. Pm me if ya wanna know more. I used it for my 401 that's in my AMX.
I may be drunk, Miss, but in the morning I will be sober and you will still be ugly.
Winston Churchill
Jesus saves..... "yea? So do my rock sliders" F.J.
frankenjeep is offline   Reply With Quote Quick reply to this message
Unread 01-27-2011, 08:33 AM   #87
TKFireman
1980 CJ7
I did a lot of reading about all the oiling mods. The conclusion I can to is that these engines have lasted 30+ years without them, and they are only really necessary if you plan to build a race engine and turn some high rpms, I could be wrong, but thats what I got from everything I read
I have debated about the timing cover, I followed this thread by jeephammer http://www.jeepforum.com/forum/f8/am...hread-1050446/, but am still thinking about going ahead and spending $250 and buying a new one.
I have some melling assembly lube that came with the kit, says to use it on bearings, camshaft and any friction points except for the pistons and rings. I went to Advance, Auto Zone and Carquest this morning looking for a moly paste that I hear I should use on the cam lobes, lifters, rockers and such, everyone looked at me like I was crazy and told me to just use the assembly lube. I thought I am suppose to use a paste that is more like grease than the assembly lube which is more like oil, am I wrong? Assembly lube for bearings, moly paste for cam lobes?
Build Thread
Unread 01-27-2011, 08:39 AM   #88
82JeepCJ7
1982 CJ7
One thing I did before I fired mine up was take an old distributor and remove the gear, and remove the shaft. I then cut the housing above the hold down. I put the shaft and housing into the motor and marked the shaft about an inch above the housing and cut it off. I use this to prime the oil system with a drill. I ran the drill until I had good oil pressure and then continued for about 5min just to make sure everything was lubed and to help work out any bubbles.
Unread 01-27-2011, 08:55 AM   #89
TKFireman
1980 CJ7
I have the original dizzy from the 401, was planning on doing the same thing, thanks 82jeepcj7
Build Thread
Unread 01-27-2011, 09:08 AM   #90
fuzz401
1978 CJ7
crane cam sells a molly lube for cams very good stuff I use it on the cam lobes /lifters/rockers http://www.summitracing.com/search/?...99004-1&dds=1; I use luriplate 105 on all my bearings crank/rods
ARP assy lube is great on head/main bolts
the oiling mod is good for higher RPM I shift mine at 6200 -6500 RPM
ther are 2 ways of doing this mod copper tube
or with braded line
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
401 , bumper build , crankshaft , dana 300 , engine rebuild , harmonic balancer , heads , nv4500 , oil pan , pistons , rebuild , rock slider , shop build
