TKFireman's build thread - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > TKFireman's build thread
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 11-30-2010, 03:38 PM   #61
swatson454
1983 CJ7
Awe man, oh well. I'll need to know the LSA, intake centerline and duration at .050. I forgot how to save it in photoshop. I played around with it the other day and couldn't figure out what I did the first time, LOL.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline   Reply With Quote Quick reply to this message
Unread 11-30-2010, 03:55 PM   #62
TKFireman
1980 CJ7
I don't know the rest of the specs on it right now, I'll get back up with you when I get the complete spec sheet from the shop. He said it may take 2 to 3 weeks, as the shop I choose is a one man business and he had a few other projects in front of mine.
"If your gonna be dumb, you gotta be tough"
Build Thread
TKFireman is offline   Reply With Quote Quick reply to this message
Unread 11-30-2010, 04:00 PM   #63
swatson454
1983 CJ7
Roger that. Are you sure it's been ordered? I'm a little skeptical about 280 degrees for what it sounds like you want to do.
Unread 11-30-2010, 04:28 PM   #64
TKFireman
1980 CJ7
honestly, my little 304 I'm replacing has good power, I can only imagine what a 401 will be like. Figured if I was gonna build an engine, might as well go big, but I doubt I will notice 10 HP or 20 ft-lbs here or there. So as long as the cam gives decent power in the lower end, its gonna be such a big difference from what I have now, I won't know the difference
A stock 304 is rated at 150 hp @4200 and 245 ft-lbs @2500
A stock 401 is rated at 255 hp @4600 and 345 ft-lbs @3300
After a few upgrades, I'm probably gonna add at least 150 HP and 100 ft-lbs to what I have now with my 304
I think 300 HP+ and 400 Ft-lbs+ is very doable
Build Thread
Unread 11-30-2010, 04:31 PM   #65
swatson454
1983 CJ7
You're probably right. Plenty O Power for a little Jeep. I think I just have issues, lol.
Shawn
Unread 11-30-2010, 04:37 PM   #66
TKFireman
1980 CJ7
For a while, I was wondering what it would be like to bring the front tires off the ground, then I remembered what it would be like to have to replace the rest of my entire drive train when it all twisted like a pretzel.
Build Thread
Unread 11-30-2010, 04:41 PM   #67
swatson454
1983 CJ7
I hear ya man. I'm sometimes guilty of the "Stroker McGurk" theory myself which states that if some is good and more is better, way too damn much must be just right.
Shawn
Unread 11-30-2010, 04:45 PM   #68
TKFireman
1980 CJ7
Funny you say that my grandpa always said "If a little will do good, then a lot ought to do a lot of good"
Build Thread
Unread 01-23-2011, 08:05 PM   #69
TKFireman
1980 CJ7
Well its been a while since I updated this. I picked up everything from the machine shop, hoping to start pre-assembly and paint this week. Here is the story from the machine shop
Block
Align honed
Bored/honed to 4.195" .030 over
decked to 9.190" from stock 9.205, so about .015 off the deck
cam bearings and all plugs installed
Heads
New guides
surfaced by .010"
valves ground
valve seats machined
2 new intake valves
new springs, locks, seals, rockers and bridges
new freeze plugs installed
Rotating Assembly
crank ground .010 under on main and rod journals
Rods reconditioned
Pistons installed
assembly balanced first spin off 14.3 grams front and 48.2 grams rear
final balance 4.1 grams front and rear
Other parts bought
Master rebuild kit, harmonic balancer, oil pick-up,
Cam specs
Melling MTA-1
----------------INT----EXH
Cam lift---------.281---.296
Valve Lift-------.450---.474
Lobe Ctr--------105----115
SAE duration----280----289
.050 duration----204----214
SAE Timing
BTC-- ABC-- BBC-- ATC
30 ---- 70 ---74 --- 35
.050 Timing
-3 --- 27 --- 42 --- -8
I'll keep ya'll updated on how it goes, but still gonna be a while, still need clutch kit, fuel and water pumps, oil stick, headers and probably a bunch more I can't think of right now
Build Thread
Unread 01-25-2011, 04:27 PM   #70
TKFireman
1980 CJ7
Got everything painted today, and checked oil pump clearance in housing, got a little bit more lapping to do. Thursday I hope to give the block a good cleaning, oil it lightly and start checking main/rod bearing clearances.
Anyone know where I can get the alignment dowels for the heads? I have all 4, but one is bent and i would like to replace it, or all of them.
Build Thread
Unread 01-25-2011, 04:30 PM   #71
benullman
1981 CJ7
Jeep porn is the best
[QUOTE=Gregg79CJ7304;11634021]Great minds think alike, but so do serial killers......Thanks.[/QUOTE]
benullman is offline   Reply With Quote Quick reply to this message
Unread 01-25-2011, 05:59 PM   #72
82JeepCJ7
1982 CJ7
What color of blue is that? It looks just like the color I used on my 360.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline   Reply With Quote Quick reply to this message
Unread 01-25-2011, 06:04 PM   #73
TKFireman
1980 CJ7
that is Duplicolor Ford dark blue, got the idea of coloring the "401" from your pictures I've seen in the past, first picture looks a little lighter in color because of the light.
Build Thread
Unread 01-25-2011, 06:08 PM   #74
benullman
1981 CJ7
Originally Posted by TKFireman View Post
that is Duplicolor Ford dark blue, got the idea of coloring the "401" from your pictures I've seen in the past, first picture looks a lighter in color because of the light.
The ford Blue is a nice blue. I used it on my I6. Looks damn good!!
Ben
Unread 01-25-2011, 06:47 PM   #75
TKFireman
1980 CJ7
Ben
Thanks Ben, still got a long ways to go.
I plan on all bolt heads, brackets and maybe a few other parts to be black, we'll see how that goes.
Build Thread
401 , bumper build , crankshaft , dana 300 , engine rebuild , harmonic balancer , heads , nv4500 , oil pan , pistons , rebuild , rock slider , shop build
