TKFireman's build thread - Page 4 - JeepForum.com
 2Likes
post #46 of 1018 Old 08-14-2010, 04:19 PM
fuzz401
1978 CJ7
yes stay away from the valve seats unless you are having new ones instaled
gudes are ok to do
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #47 of 1018 Old 08-21-2010, 05:03 PM Thread Starter
TKFireman
1980 CJ7
After around 10 hours, porting and polishing is done, hopefully I picked up some HP for a very low cost, if nothing else, I improved the short side turn, gasket matched and got rid of a few imperfections.
I found a Taurus Fan locally for $20, going to pick it up Monday I hope, going to try to sell the thermo clutch 7 blade stock fan, make up a little cash. Currently have the stock motorcraft 4350 carb on ebay if anyone is interested
Motorcraft 4350 Spreadbore Carburetor: eBay Motors (item 330463111397 end time Aug-27-10 14:49:03 PDT)
Hopefully I'll be going to the machine shop in the next few weeks, will keep ya'll updated.
Thanks again for the advice.
"If your gonna be dumb, you gotta be tough"
TKFireman is offline
post #48 of 1018 Old 09-09-2010, 12:41 PM
Fatman
Fatman's Avatar
2008 CJ7
Fireman, consider Loop Road for your machine work, I use them quite a bit, and was very satisfied with the work and price they did on my 350.
Thread Links:
Fatman is offline
post #49 of 1018 Old 09-09-2010, 01:28 PM Thread Starter
TKFireman
1980 CJ7
Thanks Fatman, I'll check them out
post #50 of 1018 Old 10-07-2010, 03:16 PM
motiv8ya
1979 CJ7
Did you hear back from the shop about what you need for a kit? I just ordered mine from Falcon Global and for $650 shipped I got a set of .040 over Federal Mogul pistons, Melling MTA-1 RV cam, Clevite Main and Rod bearings, new pushrods, lifters, Brass freeze plugs, felpro full gasket with intake valley pan, cast rings, Melling oil pump, and a timing set. Bsically everything in that kit I linked earlier plus pushrods for cheaper and no tax/shipping. Their customer service is excellent....
motiv8ya is offline
post #51 of 1018 Old 10-09-2010, 04:11 PM Thread Starter
TKFireman
1980 CJ7
The shop estimated around $550 for the master rebuild kit with RV cam. Things haven't gone as planned, taking longer to fund this project than anticipated, but once I get the money together, hopefully around mid to late November, I'll talk to them again, don't think I'm gonna go with a RV cam though after doing some reading, probably gonna go with a little bigger cam in the 262 to 270 range, right now just going to have to wait and see.
post #52 of 1018 Old 11-29-2010, 02:07 PM Thread Starter
TKFireman
1980 CJ7
Everything dropped off at the machine shop today, will keep ya'll posted
post #53 of 1018 Old 11-30-2010, 07:46 AM Thread Starter
TKFireman
1980 CJ7
Got a call from the machinist. Crank will by ground 10/10, cylinders bored 30 over. Will need to be line honed, need new rockers and bridges and heads resurfaced. He is going to install freeze plugs and cam bearings. He ordered all parts including a new harmonic balancer for me. Said he could have got a cheaper kit with steel freeze plugs and cheaper rings, but suggested that I upgrade to better stuff. I told him to balance the rotating assembly too.
I told him what I wanted the engine to do and he picked out a cam for me 280/290 advertised duration and 448/472 lift. Said it would be good for low end torgue, and give it a little rumble at idle. I'm still a little in the dark with the cams, so I'll just take his word for it.
post #54 of 1018 Old 11-30-2010, 09:38 AM
swatson454
1983 CJ7
I just realized that I completely spaced out a couple of your cam questions on another thread. Sorry about that. I'll go find them and see if I can help any.
For now, what's the valve size and where (rpm) do you want peak torque? What about gears and tire size?
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #55 of 1018 Old 11-30-2010, 10:18 AM Thread Starter
TKFireman
1980 CJ7
I was hoping you would throw in your Shawn
Valves are stock - 2.025 intake and 1.680 exhaust, most stock specs can be found here
Engine Specs page. 360 - 401
RPM range for peak torque, somewhere between 1000 to 2000 RPM, I'm not real picky and like I said, still learning, want the torque to come in at a very low RPM and have a good area under the curve. Engine probably won't ever see much over 3000 rpm, as I can run 65 at around 2600 right now. A little rumble at idle wouldn't hurt my feelings either. I don't know the LSA of the cam he picked, just taking the machinist's word for it.
Right now I have 4.10 gears and 35" tires, thinking that I will go down to 33's when I need new tires, 35's will not physically fit in the wheel wells and I don't want to do any trimming
post #56 of 1018 Old 11-30-2010, 11:51 AM
swatson454
1983 CJ7
It sounds like you want an engine that'll pull a stump without touching the throttle. Given the valve size, and rpm range you want to peak at, I'd definitely stay away from dual-pattern cams. After checking the line-up from Crane, Lunati, Comp and Isky, the closest thing I can find to what should get the job done is either the Isky 262 SuperCam or the 270 HL http://www.iskycams.com/onlinecatalog.html
It's a lighter rig and if you end up with 33 inch tires and 4.10 gears, I'd go with the 270. Problem with that is that it'll want some more compression to ward off any low-speed problems. Now is the time to address that, though, and have the shop take the deck down to get the compression up a little. Both cams seem to want 9.5:1 and, short of a custom grind, I think they're as close to 'right' as you can get.
Hopefully that helps.
Shawn
post #57 of 1018 Old 11-30-2010, 12:02 PM
benullman
1981 CJ7
swatson, not to hijack, but are there any pages you 'personally suggest' for me to look at regarding cams. IE how to pick one and what all the specs REALLY mean? I am planning out my build and I want to try to understand every aspect of it and get my whole list together of what I want before I even get the block/motor.
Ben
Originally Posted by Gregg79CJ7304 View Post
Great minds think alike, but so do serial killers......Thanks.
benullman is offline
post #58 of 1018 Old 11-30-2010, 12:26 PM
swatson454
1983 CJ7
Ben
You're going about it the right way. Here are a couple of pages that may help out. These are very general but still good. Cams are one of those deals where you can easily hear things like "Yes, definitely... most of the time" or "absolutely not, except for when..."
http://www.compcams.com/Pages/413/ca...ion-angle.aspx
http://www.lunatipower.com/Tech/Cams/CamSpecTerms.aspx
Shawn
post #59 of 1018 Old 11-30-2010, 12:40 PM
benullman
1981 CJ7
Cam Spec Terms - Lunati Power
Shawn
yeah it seems like alot of that is a depends who you ask kind of thing. I will give them a read and see what questions I have. My ultimate goal will be a fuel injected 460, if I could squeeze a compound turbo in there. The 08 F250 has one we drive and it REALLY works nice, picks up at 1200 rpm and can spit out 38psi at 80mph. Its something I think if done right would be really beneficial to a jeep for low end torque and gas mileage.
obviusly im doing ALOT of reading and planning. Im 17, if I can get this done to drive by my 20th Bday I will be on a GREAT schedule lol.
Ben
post #60 of 1018 Old 11-30-2010, 02:30 PM Thread Starter
TKFireman
1980 CJ7
Shawn, thanks for the suggestions, but the cam has already been ordered with the 280/290, 448/472 specs. Would it be possible to put that in your program and see what numbers I'm looking at and if you can post the curves like you did in the other thread, that would be sweet.
401 , bumper build , crankshaft , dana 300 , engine rebuild , harmonic balancer , heads , nv4500 , oil pan , pistons , rebuild , rock slider , shop build
86 CJ Build Thread JimNut Jeep CJ Forum 18 07-03-2012 06:54 AM
'78 CJ5 Build Thread ggerdsen Jeep CJ Forum 26 01-31-2011 08:53 AM
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 06:10 AM
Looking for a CJ Build Thread. jsc7002 Jeep CJ Forum 6 08-22-2009 10:47 AM
