tj soa on 1975 cj5 - JeepForum.com
post #1 of 5 Old 12-11-2007, 06:46 PM Thread Starter
sdhutch
1975 CJ5
tj soa on 1975 cj5
any suggestions on a soa with yj springs on a 1975 cj5 narrow trac.already have soa with 1" lift springs.1.5" wide.thanks
sdhutch is offline
post #2 of 5 Old 12-11-2007, 08:24 PM
krazyzigzagger
1976 CJ7
Get a set of rear, rear spring brackets and replace the front, front spring brackets with them. You have to replace the front spring u-bolt plates because of the wider springs.
krazyzigzagger is offline
post #3 of 5 Old 12-12-2007, 10:00 AM
jeepskate
There's a link that's been posted here several times to a write-up on earlycj5.com (you can try going over there and looking for the write-up). It's not as simple as krazy makes it sound...the info he gave you applies to '76 and up. You have to change all of your spring & shackle hangers and figure out the correct spacing for them when positioning them on the frame.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #4 of 5 Old 12-12-2007, 05:21 PM
krazyzigzagger
1976 CJ7
post #5 of 5 Old 12-12-2007, 07:07 PM Thread Starter
sdhutch
1975 CJ5
yj soa 1975 cj5
Originally Posted by krazyzigzagger
thanks for the info .sdhutch
sdhutch is offline
1975 cj5 value rajarch Jeep CJ Forum 2 08-08-2012 03:45 PM
1975 CJ5 is too SLOW!! RRenegade Jeep CJ Forum 15 04-24-2009 11:40 AM
1975 cj5 vs 1976 cj5 moose9036 Jeep CJ Forum 4 01-18-2007 10:06 AM
1975 cj5 insurance rajarch Jeep CJ Forum 3 08-30-2006 08:38 AM
Put a V8 in a 1975 CJ5 w/ a stright 6 DORF Jeep CJ Forum 2 06-28-2001 02:13 AM
