-   -   tj soa on 1975 cj5 (http://www.jeepforum.com/forum/f8/tj-soa-1975-cj5-495053/)
sdhutch 12-11-2007 06:46 PM
tj soa on 1975 cj5
any suggestions on a soa with yj springs on a 1975 cj5 narrow trac.already have soa with 1" lift springs.1.5" wide.thanks
krazyzigzagger 12-11-2007 08:24 PM
Get a set of rear, rear spring brackets and replace the front, front spring brackets with them. You have to replace the front spring u-bolt plates because of the wider springs.
jeepskate 12-12-2007 10:00 AM
There's a link that's been posted here several times to a write-up on earlycj5.com (you can try going over there and looking for the write-up). It's not as simple as krazy makes it sound...the info he gave you applies to '76 and up. You have to change all of your spring & shackle hangers and figure out the correct spacing for them when positioning them on the frame.
krazyzigzagger 12-12-2007 05:21 PM
http://www.earlycj5.com/tech/Springs...conv/index.php
Link to the details.
sdhutch 12-12-2007 07:07 PM
yj soa 1975 cj5
Originally Posted by krazyzigzagger
thanks for the info .sdhutch
The time now is 10:16 PM.
