TJ heater box in a CJ - JeepForum.com
post #1 of 12 Old 10-06-2013, 06:51 PM Thread Starter
JoeDahero
1974 CJ5
Ok I've got a crazy idea and I have a hard time believing I'm the first to think of it. My bro has an '05 TJ. The heat in that thing is nuclear. Even with a soft top he's never cold. In my '74 CJ-5 even with an aftermarket heater setup it never truly gets warm in there.
I'm on a crusade to be warm this winter. I've spent hours sealing air leaks and have bought a hard top. But I think it all comes down to CFM and the output of even the aftermarket system just isn't enough.
Which leads me to the crazy idea - graft a TJ heater box into a CJ. A complete TJ box can be had new for around $200. From FN Jeep I could prolly get one for even less. Anybody tried it? Thoughts? Suggestions? Am I crazy and committing sacrilege by suggesting such a Frankenstein and not just putting on another layer? I've searched here and google and come up empty. Curious to see what you all think.
JoeDahero is offline
post #2 of 12 Old 10-06-2013, 07:10 PM
lucdog
lucdog's Avatar
1980 CJ5
Part of the reason the TJ heater works better is the fact the engine operates at 210*. This is probably 30* more than your CJ runs.
B
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #3 of 12 Old 10-06-2013, 07:37 PM
only in a jeep cj
Ive rebuilt several CJ and a few TJ heater boxes and can tell you that the size, shape, mounting, and plumbing of the two differ enough that its not really worth it.
As a side note, I to sometimes blend parts for a better outcome. My project rockcrawler is a TJ frame and tub, but with all else CJ. I wanted the TJ frame/tub for the longarm/coils and better soft tops. Im using CJ dash/column/front clip etc for simplicity and classic look/feel. So where Im going is the TJ heater/air box will still fit behind the CJ dash when swapped over. Ill transfer the controls and lines over to the glove box or under the dash on a separate bracket. So I'll have good heat and AC with the least amount of mods (mainly the tub and mounting)
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #4 of 12 Old 10-06-2013, 08:19 PM Thread Starter
JoeDahero
1974 CJ5
Thanks for the replies guys.
The OEM thermostat in the 2.4 is 195*. My 304 is running a 195* as well. Might be some difference in engine temp but I wouldn't think it would be as much as 30*. Pure speculation though.
"Not worth the effort" has a completely different threshold driving through the mountains at night (no solar gain) when it's 20* outside and the heat is just barely enough to warm your right knee.
If my CJ were a trailer queen or summertime toy or a fair weather conveyance I might be inclined to agree about the effort. But it's my daily driver and as I'm averse to car payments and the overall concept of interest that's unlikely to change any time soon.
Based on what I'm hearing so far it sounds possible (though anything is with enough effort and imagination).
post #5 of 12 Old 10-06-2013, 08:37 PM
bamasteeler
Have you looked up the blazer blower motor mod and thought about that?? From what I have read about it everyone that does it swears by the new output.
1980 Jeep CJ7
AMC 258, T176, D300,
AMC 20 REAR, D30 FRONT
1999 XJ CLASSIC
RC 3" front AAL rear
bamasteeler is offline
post #6 of 12 Old 10-06-2013, 08:43 PM Thread Starter
JoeDahero
1974 CJ5
Originally Posted by bamasteeler
Have you looked up the blazer blower motor mod . . .
I ditched the stock box long ago in favor of the aftermarket system (Mojave type) so the cost for me to replace the stock parts and go blazer motor and going TJ would be similar.
post #7 of 12 Old 10-07-2013, 02:56 PM
gmakra
I believe the Mojave puts out 12K BTU and given your engine operating temp I would think this would make the interior reasonable.
So where is it mounted?
And do you have any blockage on your supply or return side?
gmakra is offline
post #8 of 12 Old 10-07-2013, 05:43 PM
lucdog
lucdog's Avatar
1980 CJ5
I should have put a heat range, instead of a set temp. I run a 190 in my 304's and my 360. At any rate still not as warm as a TJ .
I have read here on JF that some people block off the air flow at the cowl, and keep the fresh air door open ( inside the jeep). The reason for this is to pull warm air from inside the jeep, to be reheated.
B
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #9 of 12 Old 10-07-2013, 06:06 PM
GP_Pete
GP_Pete's Avatar
You ever thought about running two aftermarket heaters in tandem? That should melt ice off your roof. I run my stock heater in series w an aftermarket box. I kept the stock hooked up to the defrost and made 2 dash vents for the new box.
AMC 360
GP_Pete is offline
post #10 of 12 Old 10-07-2013, 07:58 PM
Blown7
I did a Vintage Air Magnum IV universal kit. Now hot and A/C beats anything.......
BEST UPGRADE EVER.
Blown7 is offline
post #11 of 12 Old 10-07-2013, 09:40 PM
tchimmerroks
1983 CJ5
When I refurbished my 4.2L '81, I thoroughly cleaned out the heater core w/muriatic acid (removed lots of scale/gunk) and combined w/the larger, heater blower upgrade, it puts out considerable heat. I've never had it in the mountains in the dead of winter, but compared to stock, it's vastly improved.
tchimmerroks is online now
post #12 of 12 Old 10-07-2013, 10:00 PM
CJ7KAHUNA
BEST UPGRADE EVER.
Got any pics? Would love to see the install.
My childhood was typical. Summers in Rangoon, luge lessons. In the spring we'd make meat helmets.
When I was insolent, I was placed in a burlap bag and beaten with reeds. Pretty standard, really.
CJ7KAHUNA is offline
