TJ Axles on a CJ7 - JeepForum.com
post #1 of 19 Old 05-03-2014, 09:10 PM Thread Starter
jeep1000
TJ Axles on a CJ7
I have been thinking about putting TJ axles on my CJ7. I want to do so for the added width, coils, and I also get a rear 44 if I get a Saharas, Rubicons, or one with a Towing Package axles. My question isnt how much itd take or what not, but, has anyone done this? What will it look like? TJs are a good few inches wider than CJs. I dont want it to look too weird either.
Jonathan
'86 CJ7, I6 258 four speed manual. See ya on the trails!
jeep1000 is offline
post #2 of 19 Old 05-03-2014, 09:35 PM
jp360cj
1977 CJ7
The TJ axles are wider but the TJ body is right about the same width as a CJ. IMO, the TJ axles are the perfect width (around 58" - 60") for a dual purpose rig.
That said, I wouldn't want to put TJ axles under a CJ. They aren't that strong for that much work/expense. You didn't say what tire size you want to run, but if I were going coils on a CJ it would be for minimum 35" rubber and that's really pushing the TJ axles.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #3 of 19 Old 05-03-2014, 10:03 PM
jeepwhore
X2. Not worth the hassle for a D30 with auto hubs, vacuum disconnect and let's not forget the obvious........the front diff being on the wrong side.
If the rear isn't going to be a 44 then it's absolutely a waste of time and resources even if you do manage to make the front work
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #4 of 19 Old 05-03-2014, 10:09 PM
JeepinJeremy
Don"t waste your time with TJ axles. Find a set of Waggy 44'S front and rear and be done with it, if you want the extra width. Other wise international scout Dana 44's are a near bolt in application and are just slightly wide than your wide track CJ. If coils are what your after, your frame is to narrow unless you swap to at least a YJ frame.
JeepinJeremy is offline
post #5 of 19 Old 05-04-2014, 04:17 AM
jp360cj
1977 CJ7
Why is the frame too narrow? TDK makes a hybrid frame that the CJ body bolts to but has brackets for TJ suspension. I would think the width would be the same?
jp360cj is offline
post #6 of 19 Old 05-04-2014, 12:33 PM
JeepinJeremy
It's narrow because that was how it was made by AMC. A YJ frame is a boxed frame and about 5" wider. I didn't say it would not work, I just said it was to narrow. Can it be used? Yes. But you would really have to outboard the brackets for it to work correctly. Not to mention the factory CJ frames are weak thin walled garbage that tend to bend and warp under stock suspension movement and would required a ton of work just to reinforce them enough to run a TJ coil spring set up. It would be easier and cheaper to run coil overs with a 3 or 4 link set up and just reinforce the rails.
post #7 of 19 Old 05-05-2014, 08:40 AM
CSP
The spring perches on a front Waggie 44 are 31.5" apart and the CJ frame is 27.5" wide, on center. You can't move the spring perches closer together on the axle because the passenger side is cast into the edge of the differential housing.
Soooo much info is on this site and the rest of the web on axle swaps and what works, what doesn't.
CSP is offline
post #8 of 19 Old 05-08-2014, 01:28 PM Thread Starter
jeep1000
So since its not worth it, I was planning on a 44/30 combo from a TJ, what axles would I consider? XJ? Stronger, wider and I get coils up front.
Jonathan
jeep1000 is offline
post #9 of 19 Old 05-08-2014, 01:34 PM
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
XJ 44 (very rare) is stronger than a TJ 44. The 8.25 is weaker. The turdy 5 is, well, a turd.
Front axle CAN be stronger (based on what XJ you find as the source) but its the ring gear, not the axle shaft.
However, the axles are the same width (not wider) and you still are posed with all of the same problems as if you were to swap in TJ axles.
2016 TJ of the Year
Founder,
EugeneTheTJ is offline
post #10 of 19 Old 05-08-2014, 05:40 PM
CSP
TJ, XJ, YJ, ZJ etc all have the front diff on the wrong side for a CJ.
Do a Google search on "CJ axle swap". That will give you an idea what works and why they work. You're not really coming up with ideas that haven't been considered before, so a backwards way of thinking with a lack of documentation of such swaps is an indicator that they aren't good or viable candidates.
CSP is offline
post #11 of 19 Old 05-08-2014, 08:57 PM Thread Starter
jeep1000
My goals are springs (front and rear or just front), and width. Leafs are nice and stock, but damn they are stiff on the rocks.
Jonathan
jeep1000 is offline
post #12 of 19 Old 05-09-2014, 08:16 AM
CSP
Not if you use the right leafs and set them up correctly.
CSP is offline
post #13 of 19 Old 05-09-2014, 08:35 AM
BlueRubiconrich
front axle: the right year Waggy 44 or Scout Dana 44
rear axle. Scout Dana 44,Ford 8.8, Ford 9"Honda passport Dana 44.,Waggy 44
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #14 of 19 Old 05-09-2014, 09:29 AM
Tfain
1978 CJ5
I think if your really that concerned about the suspension just do a 4 or 3 link. I don't think just swapping over to coils would be worth it. It can be better but I don't think it's that much better to justify what it's gonna cost to do it. You'll get softer suspension with a 3 or 4 link and much much more flex
Tfain is offline
post #15 of 19 Old 05-09-2014, 10:18 AM
CSP
Coils require links too.
Pretty sure you're referring to using coil overs vs. coils.
CSP is offline
