tires & wheels - JeepForum.com
post #1 of 4 Old 05-17-2007, 01:25 PM Thread Starter
jaydo
tires & wheels
86 cj 4" suspention lift , 1" body lift, 3/4" shackle lift. what size tires can i put under it. looking at 35x14.5x15 ss boggers ,4"back spaced wheel. but i think i could fit 37"x13.5x15. anybody run anyting close to that or bigger. thanks
jaydo is offline
post #2 of 4 Old 05-17-2007, 01:38 PM
bdmonist
WTF is that?
bdmonist's Avatar
I have a 4 inch suspension, 2" body, 1 inch shackle and have 35'sx12.5. Haven't had any problems yet, but they will probably rub when compressed heavily. What is stock backspacing? A tire that wide needs to be farther out than stock I would think.
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift.
In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles
Coming Soon - CV Shafts, Welded Tubes, trusses
bdmonist is offline
post #3 of 4 Old 05-17-2007, 03:33 PM
jeepskate
I have about 1/4" less lift than you and run 35x12.5's comfortably. Swampers tend to run true to size, so the 35's will probably be your limit. 37's would technically fit, but you'd have very little room for travel (and assuming you still have stock axles you'd really be pushing it strength-wise).
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #4 of 4 Old 05-17-2007, 05:04 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
I would consider a 3 something back space...those wide boggers will play hell on your springs when turning...they have massive side lugs...
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
Wheels and Tires ???????? arcticj7 Jeep CJ Forum 0 05-29-2009 09:38 PM
MT tires and wheels SCHUSKER Jeep CJ Forum 2 08-29-2007 04:45 PM
TOTW TIRES & WHEELS RockJeep Jeep CJ Forum 24 07-12-2005 11:26 PM
Weight of tires & wheels coyote69 Jeep CJ Forum 2 12-27-2004 01:59 PM
got my new wheels and tires NJCJ7 Jeep CJ Forum 3 09-21-2004 12:18 PM
